Some pics to talk about
Discussion in 'Electrical Forum discussion & Blog' started by jaxbldginspector, Feb 13, 2009.
  1. jaxbldginspector
    jaxbldginspector New Member
    Mar 19, 2008
    Romex 10/2 w/g
    Romex 10/3 w/g
    Romex 12/2 w/g
    Romex 12/3 w/g
  2. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Time to do some derating calculations.
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Not if they remove that tape. ;)
    WTH is all that #10 for???
  5. codeone
    codeone Code Enforcement
    Sep 5, 2008
    Code Enforcement, Instructor
    North Carolina
    Check out the 2008 NEC. Removing the tape doesnt matter. Its still considered bundling, you need to derate!
  6. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    So that's where my flux capicitor went
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    How do you figure? What would you consider "maintaining spacing"?
  8. codeone
    Sep 5, 2008
    North Carolina
    May be bundling in the sense you are used to is not the correct term I should use. However it would have to be derated per 2008. I personally would still say it is bundled for derating purposes there is no spacing between those conductors and would not pass the job. See below note last two paragraphs.
    334.80 Ampacity. The ampacity of Types NM, NMC, and
    NMS cable shall be determined in accordance with 310.15.
    The ampacity shall be in accordance with the 60°C (140°F)
    conductor temperature rating. The 90°C (194°F) rating
    shall be permitted to be used for ampacity derating purposes,
    provided the final derated ampacity does not exceed
    that for a 60°C (1400 P) rated conductor. The ampacity of
    Types NM, NMC, and NMS cable installed in cable tray
    shall be determined in accordance with 392.11.
    Where more than two NM cables containing two or
    more current-carrying conductors are installed, without
    maintaining spacing between the cables, through the same
    opening in wood framing that is to be fire- or draft-stopped
    using thermal insulation, caulk, or sealing foam, the allowable
    ampacity of each conductor shall be adjusted in accordance
    with Table 310.15(B)(2)(a) Exception shall not apply.
    Where more than two NM cables containing two or more
    current-carrying conductors are installed in contact with thermal
    insulation without maintaining spacing between cables the
    allowable ampacity of each conductor shall be adjusted in
    accordance with Table 310.15(B)(2)(a)
  9. Speedy Petey
    Jun 16, 2007
    NY State, USA
    These cables are neither:
    "through the same
    using thermal insulation, caulk, or sealing foam,"
    Nor are they:
    "installed in contact with thermal
    insulation"
    So the last two paragraphs do not apply.
    If they were, or are to be, then the last two paragraphs apply.
  10. codeone
    Sep 5, 2008
    North Carolina
    These cables are going through the draft stopping band of the floor joist as per the building code.
    Requiring the holes to be sealed.
  11. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Since when does a horizontal hole need to be firestopped?
  12. codeone
    Sep 5, 2008
    North Carolina
    R502.12 Draftstopping required. When there is usable space
    both above and be low the concealed space of a floor/ceiling as -
    sembly, draftstops shall be in stalled so that the area of the con
    -cealed space does not exceed 1,000 square feet (92.9 m2).
    Draftstopping shall divide the concealed space into approxi -
    mately equal areas. Where the assembly is enclosed by a floor
    membrane above and a ceiling membrane below draftstopping
    shall be provided in floor/ceiling assemblies under the fol low -
    ing circumstances:
    1. Ceiling is suspended under the floor framing.
    2. Floor framing is constructed of truss-type open-web or
    perforated members.
    R502.12.1 Materials. Draftstopping materials shall not be less
    than 1/2-inch (12.7 mm) gypsum board, 3/8-inch (9.5 mm) wood
    structural panels, 3/8-inch (9.5 mm) Type 2-M-W particleboard
    or other approved materials adequately supported.
    Draftstopping shall be in stalled parallel to the floor framing
    members unless other wise approved by the building of ficial.
    The integrity of all draftstops shall be maintained
    R502.13 Fireblocking required. Fireblocking shall be pro -
    vided in wood-frame floor construction and floor-ceiling as -
    semblies in accordance with Section R602.8.
    R602.8 Fireblocking re quired. Fireblocking shall be pro -
    vided to cut off all concealed draft openings (both vertical and
    horizontal) and to form an effective fire barrier between sto -
    ries, and between a top story and the roof space. Fireblocking
    shall be provided in wood-frame construction in the following
    locations.
    1. In concealed spaces of stud walls and partitions, includ -
    ing furred spaces and parallel rows of studs or staggered
    studs; as follows:
    1.1. Vertically at the ceiling and floor levels.
    1.2. Horizontally at intervals not exceeding 10 feet
    (3048 mm).
    2. At all interconnections between concealed vertical and
    horizontal spaces such as occur at soffits, drop ceilings
    and cove ceilings.
    3. In concealed spaces be tween stair stringers at the top and
    bot tom of the run. En closed spaces under stairs shall
    com ply with Section R311.2.2.
    4. At openings around vents, pipes, and ducts at ceiling and
    floor level, with an approved material to resist the free
    pas sage of flame and products of combustion.
    5. For the fireblocking of chimneys and fire places, see Sec -
    tion R1001.16.
    6. Fireblocking of cornices of a two-family dwelling is re -
    quired at the line of dwelling unit separation.
  13. codeone
    Sep 5, 2008
    North Carolina
    Please note these references are from the 2006 NC Residential Building code based on the 2002 ICC Residential Codes.
  14. codeone
    Sep 5, 2008
    North Carolina
    Also if this is a basement thats not going to be finished at this time without a heating system it could be required to be insulated. Then you would have to derate for the thermal insulation also. Another possibility is insulating for sound control also would need to be derated.
  15. codeone
    Sep 5, 2008
    North Carolina
    According to 310.15(B)(2)(a) more than 41 current carrying conductors have to be derated by 35% Which means you could not even put a 15A breaker on those #10's. in the first picture on the left if I counted correctly. Hard to see actually how many conductors are there.
  16. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Sounds like some bad math.#10 would be 30 amp without derating. 30x.65=19.5 amps, which would allow a 20 amp breaker.
  17. Speedy Petey
    Jun 16, 2007
    NY State, USA
    You do not derate from the 30A figure. You use the actual temperature rating of the wire, which is the 90 deg C column for new THHN conductor NM cable.
    #10 NM cable is derated from 40 amps. And you do not derate by 35%. You derate TO 35%.
    Even at a 35% adjustment you CAN use a 15A breaker since we round UP to the nearest standard breaker size.
    40 x 35% = 14A = 15A breaker
  18. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    It is 35% not 65%
  19. codeone
    Sep 5, 2008
    North Carolina
    Thanks Speedy Petey that rounding up rule is one I forget once in a while.:eek:
    Still the caculation does come out to less than 15A. I still say the wiring routes taken are very bad practice.
  20. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    I didn't dig out my copy of the code, but took Codeone's statement "by 35%" at face value. I just did the math check.
    I did remember the "next larger standard overcurrent device"
    :D.
  21. codeone
    Sep 5, 2008
    North Carolina
    Just for debate we need to look at Article 334.80 of the NEC . Looks like it rules out the next highest breaker with two words.
    334.80 Ampadty. The ampacity of Types NM, NMC, and
    SHALL be permitted to be used for ampacity derating purposes,
    PROVIDED the final derated ampacity does not exceed
    Now I'm not saying some AHJ's dont allow this, however it is something to consider. It may be just bad wording to give the intent. That happens sometimes.
Similar Threads: pics talk
Electrical Forum discussion & Blog What is the size of my electrical service (pics) Feb 2, 2011
Electrical Forum discussion & Blog Leaky well pipe (PICS attached) Oct 29, 2009
Electrical Forum discussion & Blog complicating-updating new box for client, electrician F***** it up-pics included Aug 22, 2007
