Solder supply lines to valve or use threaded?
Discussion in 'Shower & Bathtub Forum & Blog' started by johngaul, Nov 14, 2007.
  1. johngaul
    johngaul New Member
    Nov 5, 2007
    VA
    Installing a Delta R18222 shower valve in master bath. Both the outputs are solder connections, yet the inputs are threaded. Shouldn't I solder these as well since they will be enclosed?
  2. jadnashua
    Most of those valves will allow either a threaded connection, or you can slide the pipe into the opening and solder it there. If you remove the cartridge and clean and flux the pieces, a soldered connection is probably better. Either one can work if done right, though. Don't solder a threaded connection since, if you ever do want to disassemble it, it will be a major pain.
Similar Threads: Solder supply
Shower & Bathtub Forum & Blog electrical vs. plumbing solder Aug 16, 2015
Shower & Bathtub Forum & Blog Soldering on the grill - really. Jul 17, 2015
Shower & Bathtub Forum & Blog Shower Valve Solder Leak Aug 3, 2014
Shower & Bathtub Forum & Blog Do pros solder shower valves before or after installing? Mar 18, 2014
Shower & Bathtub Forum & Blog Delta R10000 installation...leave plastic screen in during soldering?? Aug 14, 2013
