Mikebarone
DIY Senior Member
HI, I need to join a 1†copper line using standard copper fittings. One of these splices will be in an attic, and the other one will be under the concrete house slab.
I have been told that a normal solder connection will be fine. I’ve also been told to braze them together using a copper phosphorus rod. And then I have also been told that I need to braze them together using a Silver solder rod. Depending on what I need to use, will Mapp gas work? Thanks, Mike
