Your not asking the right questions. Most plumbers just have personal preferences. You can tell that just by reading so many different responses. The type of flux and what materials arn't the question, I'm non brand loyal, I use whatever.... I work for a shop that uses only copper water lines, so I run alot of pipe, and it's not the materials, it's how you use it. I have about one to three leaks a year. You have to practice. If you are a beginner you should start with propane. It won't "burn" the flux out as quickly. Only use enough heat to make solder flow. Only use as much solder as needed. (a 1/2 inch fitting only takes a 1/2 inch of solder). Take a piece of pipe and put a coupling on the end of it. heat it up gently, and slowly until the solder starts to flow. and only enough so that it doesn't quite drip. Let it cool. inspect. Look inside if it is ringed all the way around, and same on the outside It's a great joint. If not cut it off and try again. Each and every joint is different, the trick is to get the fitting and the pipe up to temp at the same time all the way around... If it's a ball valve your soldering, than spend a lot more time with the heat on the valve and work it around to bring it's temp up. Use your minds eye to see the pipe heat up and think of what parts might be too hot or too cold. It is true that most solder and flux is different, but the only way you will find out what is best for you is to experament... have fun with it... and what you will find is that your preferences are totally different than anyone elses. good luck
dances-with-pumps
