David S
Hello! We moved into a new house and that was a spec and no softener loop was installed. I found my main line coming in and it’s in the laundry room so I’m going to put my system there since I have a drain and everything I need. My question is can I drain the softener down the same drain the washing machine uses? The second question is I’m looking at the fleck system, either the resin tank and brine separate or the all in one. I don’t think the brine tank overflow will be higher than the washing machine drain. Can I use the clean out and put a p trap down there since it’s lower? See pic below. Thank you for the advice and help!!!
