Smelly hot water even after new anode rod
ChopperRS
Minnesota
I was having issues with a rotten egg smell in my hot water and replaced the anode rod. Although the rod had a dark scummy coating on it, it had not been reduced in length or thickness. With the new rod n place, I had almost two weeks of smell free water, but now the rotten egg smell has returned stronger than ever. I am on a well system. The whole upstairs reeks following morning showers. Help needed. - Richard
Unfortunately a new magnesium, or even aluminum, rod can increase the smell compared to an exhausted rod. A powered anode protects like magnesium or better, and it does not facilitate H2S production.
I suggest you crank up the WH temperature now to minimize SRB growth. Also I would sanitize my well and plumbing system, presuming you are on a well. https://terrylove.com/forums/index....izing-extra-attention-to-4-inch-casing.65845/
sanitizing can have a very good effect. Some use a simpler procedure than what I use. It can help, but it is not as long-lasting.
Anode rods are available in more than one metal. Some can react with your incoming water and produce some smells. The solution is to use one made with a different metal, or condition your water to enable the 'standard' one to work without problems.
brighteyesfordemis
I've been trying to figure out why, after three weeks or so, after replacing my anode rod, my hot water smells like eggs again?
brighteyesfordemis
... How do I know what metal rod I should get?
brighteyesfordemis
I'm having a very similar problem. I recently replaced my anode rod about three weeks or so. Everything was fine, but now that rotten egg smell has returned...What did you do to solve your problem?
Thanks,
James
I used a Ceranode powered anode. It protects like magnesium, but does not react to help produce H2S.
Its electrode stretches to match the length of the old anode. There are stubby anodes that are cheaper, but I expect them to offer less protection.
At the cheaper end, many just replace the anode with a brass plug to avoid the H2S generation. https://culligan.com/home/solution-...o-treat-sulfur-water-and-reduce-the-rotten-eg
Some treat the WH with hydrogen peroxide periodically. Including the WH in you well and plumbing sanitizing can help, at least for a while.
