smartwater not drawing brine
Discussion in 'Water Softener Forum, Questions and Answers' started by rightlane, Apr 2, 2010.
  1. rightlane
    rightlane New Member
    Apr 2, 2010
    az
    Hello all, as the title states i have no suction in brine mode. i replaced the what came with the rotor disc seal kit and cleaned the venturi, and i'm able to suck brine through the float. when in brine mode i removed the hose from the venturi to check if it was sucking and it still isn't. in fact it has a dribble of water coming from it, the venturi, not the hose. when it switches from brine to rinse i get suction for a couple of seconds and then it stops. i don't have any external leaks that i've found. the disc looks clean and unscarred, i'm stumped. any help would be greatly appreciated. thanks, Chris
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Double check first if you have the manual to make sure that each and every part is in the right spot and the right way in that venturi housing... if some thing is out of place there it will not work right.
    If that is all correct.. in the valve where you replaced the rotor disc seal kit, make sure that the O ring that looks like an 8 is in right, that the spring that is under a pluger is there.. in the book that I have on page 25 they are parts 122,123 ...
  4. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    Check your drain for a restriction. I have seen junk pile up at the elbow where the flow control is. If not plugged, pop the clip for the venturi and move it to the side. With the unit on bypass and depressurized, advance the valve to brine draw. Slowly open the bypass and watch the water spray out one port of the venturi. If it comes out of both ports, the fig 8 o ring is bad.
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    Now see, I am going to have to remember that last little part about which hole to have the water come out of ... is it the top or the bottum? or middle?
  6. rightlane
    Apr 2, 2010
    az
    thanks for the quick replies. the venturi is set-up correctly, it was previously working and is put back together the as the manual shows. the drain is clean, i pulled the venturi while in brine draw and got wet. lots of water out of bottom hole, slow trickle from top, suction from neither. the figure 8 o-ring has been in the softener for about 2 minutes, just replaced hoping it might be the problem. what's my next step? again, i appreciate your help. thanks, Chris
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    The figure 8 O ring goes in only one way right?
    The spring is still in place under 123 the drain seal?
  8. rightlane
    Apr 2, 2010
    az
    i popped the top off to be sure, but the drain spring is still there, and i pulled the figure 8 o-ring and it doesn't go in any other way. thanks, Chris
  9. Akpsdvan
    Dec 29, 2009
    Alaska
    If the spring, then the plunger and the O ring that is on top of that plunger are in place and working...
    And the rotor is in the brine draw spot , and injector housing is all correct.. is there any water going to the drain?
  10. rightlane
    Apr 2, 2010
    az
    there is water going to the drain in rinse and backwash cycles. i'm pretty sure there is water going to the drain as it tries to draw a venturi during brine draw cycle or at least it sounds like water is rushing at the start of brine draw. i'll check the venturi setup again. thanks, Chris
  11. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    Water should only come out of one port during the draw cycle. Put the unit into a draw cycle. Disconnect the motor plate from the top and manual turn the cam jus a little and see if you get a draw. If you get a draw, the rotor needs to be replaced. Keep me posted.
  12. rightlane
    Apr 2, 2010
    az
    rotor disk replaced, all new rubber throughout, still no brine draw and water dripping out of venturi setup when i dc the hose, getting ready to kill it with fire. please help. thanks, Chris
  13. Akpsdvan
    Dec 29, 2009
    Alaska
    Water dripping out the brine assembly..
    If the drain was plugged that would have water not dripping but running..
    Rotor disc can only go in one way..
    Is there like a green layer above the red rubber disc in the brine assembly?
    From the base up there is the flow control in one hole, a screen in another and then red rubber disc.. then there is a blue like plate with another flow control in it, then the ring and a rubber o ring and the screen hat..
  14. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    If you are getting a drip from the venturi during brine draw, the fig 8 o-ring is bad or put in wrong.
  15. rightlane
    Apr 2, 2010
    az
    rechecked everything and started a cycle with no change, water dribbling out of venturi, manually advanced the gear mech and suction started! the rotor has been replaced but didn't solve the problem. is there a chance that the gear has become misaligned?
  16. Akpsdvan
    Dec 29, 2009
    Alaska
    I would go with the micro switch not tight or alinged right.. any chance that little micro switch has been moved at all?
  17. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    This tells me the rotor shaft is twisted. If the unit, while in brine draw, will not draw brine, but will if you turn the gear a little, then the rotor shaft is twisted.
  18. rightlane
    Apr 2, 2010
    az
    is the rotor shaft part of the rotor disc that i just replaced? is it what slides into the geared mechanism from below? i'm wondering if the geared mech might be off a bit. is the shaft a replaceable part? thanks
  19. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    The shaft is part of the rotor. Did you replace the rotor or the rotor seal? The only other possible cause is the micro switch but the arm would have to have been bent. I've have never seen this before but can see it happening. In fact, take a pair of pliers and straighten the arm on the mirco switch slightly. This will keep the motor on longer and maybe start the brine.
  20. rightlane
    Apr 2, 2010
    az
    is the micro switch the little tab making contact?
  21. Skip Wolverton
    Dec 27, 2009
    Ocala, Fl
    Yes. It rides on the silver cam so when a notch comes around, the switch opens and stops the motor. If the micro switch has an arm sticking out that contacts the cam, it may have gotten bent which would change the timing.
Similar Threads: smartwater drawing
Water Softener Forum, Questions and Answers GE Smartwater GXSF23Z01 wiring diagram Dec 20, 2014
Water Softener Forum, Questions and Answers GE Smartwater Softner Dec 31, 2012
Water Softener Forum, Questions and Answers Low Pressure Out of GE Smartwater Softener Nov 23, 2010
Water Softener Forum, Questions and Answers Performa valve not drawing chemical Dec 29, 2016
Water Softener Forum, Questions and Answers Rainsoft Q2 not drawing brine during cycle -- any suggestions? Oct 8, 2015
