Slow Draining Sink except when AAV is removed...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mdistel, Aug 14, 2007.
  1. mdistel
    mdistel New Member
    Aug 14, 2007
    If I untwist one of the Oatey Air Admittance valves under either the main kitchen sink or the island sink the sink drains normally. Otherwise I hear gurgling, usually in the island sink. I put a plastic bag over the AAV pipe and unscrewed the AAV, the bag filled with air when I ran the sink. Isn't an AAV supposed to allow air in, not out? What is the likely problem?
    Mark
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    you might have slow drain or stoppage.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    try a new AAV
    It could be the AAV going bad....
    but their is a better chance that the drainline is
    beginning to get stopped up.....
    probably need to clean it out and see if that solves the issue
  5. hj
    aav
    YOu are correct in that the AAV lets air in, but not out. That is your problem. Air is being trapped in the pipe, and since the air cannot be vented because of the AAV, the water either cannot drain, or cannot drain very fast.
  6. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    mdistel,
    If you don't hear a suctioning sound while the vent is in place...replace it.
    Look for a "Studor" vent.
    If the problem where positive pressure, you'd likely have overspill when the vent were removed.
    You could do a simple test by putting your hand over the hole while the sink is draining.
  7. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    That's not making sense to me, Grumpy.
    If the bag's filling with airl... by definition... that's positive pressure, isn't it?
    Are you using those words in some specialized, plumber-ese, technical sort of way or something?
  8. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    There's likely a mechanical vent there because the drain drops into the floor after the trap.
    When the waste water drops, it creates a suction...not positive pressure...without a vent for the vacuum it drains slower.
  9. hj
    drain
    He already stated that there is an AAV. Suction/vacuum speeds up drainage. Vents stop vacuum thus slowing drainage rate down to whatever the water's head pressure will generate. Positive pressure slows or stops drainage.
  10. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    I missed the part about the bag filling...geesh.
    Ten to one the drain is either undersized, or blocked.
  11. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Also...why wasn't the island bow vented?
  12. mdistel
    mdistel New Member
    Aug 14, 2007
    Thank you for all the replies. Both the island and the main sink are vented. I'll have to have a plumber come sank the lines, I tried and didn't get anywhere. Now I need to find a good plumber in the Cleveland area.
    Mark
  13. hj
    vent
    For the same reason AAV's are used anywhere. It is cheaper. But if the drain line is plugging, then a bow/loop vent will give the same symptoms as an AAV.
  14. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Right, I keep forgetting mechanical vents are allowed in some states.
    Here bow vents are an art...we take pride in them.
    If this work was done on the cheap, then I'm putting my money on the common drain being 1-1/2", maybe 1-1/4".
Similar Threads: Slow Draining
Plumbing Forum, Professional & DIY Advice Moved and replaced sink. Now slow draining Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Bathroom sink started draining slowly Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Slow draining sink (a.k.a - Pulling my hair out in Omaha) Nov 29, 2015
Plumbing Forum, Professional & DIY Advice Urinals - Slow draining Dec 9, 2014
Plumbing Forum, Professional & DIY Advice new kitchen pipe slow draining Apr 18, 2014
