Slant fin as underfloor radiant heat?
Discussion in 'HVAC Heating & Cooling' started by rbrtferry, Oct 2, 2007.
  1. rbrtferry
    rbrtferry New Member
    Oct 2, 2007
    I am currently in the process of reconfiguring my 3/4 inch baseboard heat pipes ...to match the requirements of zone 1(bedrooms) and zone 2 (kitchen & cathedral ceiling LR). In one of the busy circuits, I was thinking of installing a length of slant fin heater directly under the center of the bathroom for radiant heat. I figured on putting in some sheetmetal first (to spread the heat) then sweat in the slant fin with the fins touching the sheet metal, then covering it with insulation, maybe a piece of foam board type, creating a pocket in the bay.
    Anyone ever do this? I didnt want to get into a pex project at this time. I am a novice plumber but competent.
  2. CHH
    CHH New Member
    May 25, 2007
    Denver, CO
    I'd say that running 180 degree water as underfloor radiant heat would probably be a bad idea. Most (all?) radiant systems use lower temperature water. Barefoot on a surface that exceeded 120 degrees would "cause the subject to display signs of discomfort" or some such understatement for a rather dry laboratory description of pain.
    You might get away with it if the 'heat spreader' had a pretty good air gap under the subfloor. There would be no need to use a slant fin radiator since the sheetmetal would prevent convection through the radiator.
  4. biffnh
    biffnh New Member
    Jul 16, 2006
    retired chemistry teacher
    Squam Lake, New Hampshire
    I did this but did not use the sheetmetal. Instead I just put sections of the lenghts of the radiator fins under the floor between the floor joists in a serpentine fashion in the middle of the bathroom floor. I then placed my cement board and ceramic tile down. It works very well!! It is now 4 years since I built the bathroom and it was well worth the small expense and time. I fit foil-faced polyisocyanurate 2" insulation panels in between the joists under the radiator sections.
  5. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    I miagine the heat exchange is pretty efficient, but - wouldn't that be a ridiculously expensive way to do it?
  6. biffnh
    biffnh New Member
    Jul 16, 2006
    No - not expensive at all and efficient as well. The baseboard sections are in series with the 4 foot baseboard section on the wall providing immediate heat while the underfloor sections keep the tile floor warm and provides a longer heat source due to the thermal mass of the cement backer board and the tile. The water going through the under floor sections is the normal 180 degreee that goes to the baseboard unit - no tempering valve is needed. It seems to work very well.
  7. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    efficient and inexpensive. Very smart.
    jsut to be sure i have been able to grasp what you are saying, what does "a pocket in the bay" mean?
    david
  8. biffnh
    biffnh New Member
    Jul 16, 2006
    The "pocket in the bay" is just the volume between the floor joists. In the bathroom that I have done this in had a full unfinished basement so access was easy when I plumbed it. I ran the sections of finned baseboard pipe (minus the finished sheet metal) in the middle of the first bay, turned to the next, back down it and then turned to the next and so on. I have about 5 sections of radiator pipe done this way. Hope this helps.
  9. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I am thinking about doing the same kind of thing for heating a 15'x23' second-floor room. I have found some slant-fin tubes (sans covers) that will give off 350 btu/hr/ft from 140* water at 1 gpm, and that makes a lot more sense to me than using PEX at about 1/7 of that output:
    350 sq.ft. x 50 = 17500 btu minimum
    17500 / 350 = 50 ft. @ $7/ft for slant-fin ($350.00)
    17500 / 50 = 350 ft. @ $.5/ft for PEX ($175.00)
    Am I thinking clearly here?
Similar Threads: Slant underfloor
HVAC Heating & Cooling HD Slant/Fin Dec 14, 2009
HVAC Heating & Cooling Slant coil problem Oct 16, 2008
HVAC Heating & Cooling New Slantfin cover for old baseboard heat Dec 8, 2007
HVAC Heating & Cooling SlantFin VHS 120 Boiler short cycling Aug 10, 2007
