Slab top-side vapor control — Airspace approach
Discussion in 'Remodel Forum & Blog' started by lmei007, Feb 24, 2012.
  1. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    Read the "READ THIS BEFORE YOU DESIGN,BUILD OR RENOVATE" doc and found above recommendation on page 13 or 19, Or view it here (click me). Many of you here, including Dana, seems like "poly + foam + plywood" approach for basement floor. Above approach is "dimpled + foam + plywood".
    The dimpled is more expensive than poly. is it worth to spend several hundreds more?
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    I haven't seen any good science that would indicate a need for dimpled membrane rather than 10-mil poly as a capillary break when retrofitting a slab. The wicking potential of either poly or XPS is extremely small, and no-wicking/drying toward the basement==no mineral depletion of the concrete. The slab itself doesn't "need to dry", and encouraging moisture migration through the slab only degrades it. The additional benefit of having an air-space between the extremely low-permeance non-wicking poly sheeting and the concrete is academic.
    Dimpled membranes may be useful under ceramic or wood flooring with NO foam with damp slab, where a rip in a poly sheet might allow some wicking of moisture into the ceramic, staining it. But with an inch of (no-wicking low-permeance) XPS that's not a likely scenario.
    If the water table is occasionally high and you regularly get wet spots or efflorescence on the slab, use a concrete sealer on it before the poly + foam.
  4. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    Do I need to leveling the floor before put poly+ foam?
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    If you were planning to use a cement based floor leveler it'll bond better and have fewer cracking issues if you apply it to the slab, and not on top of the foam.
Similar Threads: Slab top-side
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog How to deal with sloppy slab when pouring sidewalk adjacent Mar 28, 2015
Remodel Forum & Blog Can I put everything in one trench in slab? Sep 27, 2013
Remodel Forum & Blog Hardwood slab on grade Apr 21, 2013
Remodel Forum & Blog cutting and patching a lower square in my basement concrete slab for treadmill Sep 28, 2012
