Sink drain into floor drain.
NickLo
Maryland
Hello everyone. I did not see a post about this and wanted to check how the best way (following code) to do this..
I wanted to install a sink for a wet bar in my basement. I have a floor drain that connects to a sump that is connected to my main septic tank. The floor drain also catches any water from my water heater, and hvac. What is the best way to connect the sink, catch the hvac/WH and properly vent this(assuming I need that too)?
I was planning on the sink being as close to this drain as possible on the other side of the framing in the pic.
Thanks for the help.
John Gayewski
Iowa
I think I'd turn that into a mop sink. This receptor that you have fashioned is getting pretty crowded and is not really what I'd call a floor drain. Each fixture dumping into it needs an air gap of one pipe diameter. So a 2" sink drain needs to be two inches above the receptor. Kind of hard to do all of that with what you got.
NickLo
Maryland
Thanks for the reply, but don’t need a mop sink. Already have one in the laundry room. I could make a tiered vertical drain line with an access cap on top and combine the drain lines to free up some space.
John Gayewski
Iowa
The drains can't connect. So yeah you could it's just a silly look.
