single zone of muti-zon system not circulating
Discussion in 'HVAC Heating & Cooling' started by KenB, Mar 31, 2008.
  1. KenB
    KenB New Member
    Mar 31, 2008
    I have a boiler with 3 (taco) zones (air handlers on two floors and an indirect water heater) and a single circulator (taco). For some reason one of the zones provides no heat. I noticed when the thermostat calls for heat the air handler kicks on, the zone valve opens and the boiler fires up, however no circultion of hot water occurs. It was working fine, then intermittently started this behavior which is now constant. If the circultor works for the other zones what could be the problem?
  2. jadnashua
    air in one zone can prevent the circulator from moving water through it. The typical head of a circulator pump can't pump through air, but it can push water since it is aided by that falling down from the high side, but it may not be able to build enough pressure to push it up the hill otherwise.
  4. KenB
    KenB New Member
    Mar 31, 2008
    Thanks. I thought about that but I can get it to serve heat if I shut the other zones off completely and recycle the thermostat setting calling for heat. But not always.
Similar Threads: single zone
HVAC Heating & Cooling Mini Splits, Single vs Multi Zone Condensers Sanity Check Jul 21, 2016
HVAC Heating & Cooling Central Air: Attic Ductwork Layout for Single Zone. Jul 3, 2009
HVAC Heating & Cooling Dual zone vs. Single zone? Mar 3, 2009
HVAC Heating & Cooling DIY baseboard hot water heat design help for a single room Jan 31, 2014
HVAC Heating & Cooling Skinny Wall mount single room Air Conditioners May 14, 2012
