single, moen; not getting hot water!!! plz help
Discussion in 'Shower & Bathtub Forum & Blog' started by maor, Dec 4, 2008.
  1. maor
    maor New Member
    Dec 4, 2008
    Few months ago a handyman remodel the upatairs bathroom, I tried to shower but didnt get hot water...!!!!any suggestions will be appreciated!!
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Under the handle is a hot limit stop it probably needs to be adjusted properly.
    Do you know what the model # is?
  4. maor
    maor New Member
    Dec 4, 2008
    Thanks for replying!! and no i dont know the model#...! i took it apart ..... and it does have some plastic stopppers but even when i turn the water on with out them it still comes out cold ... i only get a little warm after i pass the 180 degree turn but only get a tritkle of water!!Any suggestions !!!
  5. jadnashua
    Sounds like one of two things: the pressure balance spool valve is stuck, or there is some debris caught in the hot inlet. If there's an in-line stop valve, it could be closed. How old is the house? Could there be some galvanized pipes in there that are all clogged up with rust?
  6. maor
    maor New Member
    Dec 4, 2008
    im not sure around 50s and ill check for the galvanize pipe!!!\
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Or the handyman melted down the cartridge...:mad:
    Answer the questions in the pull down menus under
    DON'T KNOW YOUR MODEL OR REPLACEMENT PART NUMBER?
    At this link and find your valve.
    http://www.moen.com/buymoen/buyparts/index.cfm
    Sounds like it might be a posi-temp.
Similar Threads: single moen
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen single handle shower is slow to fully start and slow to stop Dec 28, 2015
Shower & Bathtub Forum & Blog Increasing the flow rate of a Moen Voss Voss-Single-Handle-High-Arc-Lavatory-Faucet Sep 27, 2013
Shower & Bathtub Forum & Blog Alignment of Moen plaster ground (single handed shower faucet) Apr 30, 2013
Shower & Bathtub Forum & Blog Hot/Cold Reversed on Moen Single Handle Shower Knob Apr 15, 2012
