single handle, shower, no hot
mandc421
Colorado
10 year old single handle, twist only, in a small basement shower. i removed the cartridge and cold water shot out, plenty of pressure. zero hot water is coming out. this started probably with in the last 6 months. unknown make and model. no visible sign of mineral build up, no leaking. i'm thinking the balancing valve has failed and whole unit needs to be replaced.
your opinion please.
You could have something like a Delta Scald Guard with a separate balancer. If so, there will be a "nut" on the body, usually to the right of the handle, to replace it. You do not replace the valve when a balancing spool gets stuck.
