Sine wave monitor
Discussion in 'Electrical Forum discussion & Blog' started by r_2016, Jul 24, 2009.
  1. r_2016
    r_2016 New Member
    May 25, 2007
    Hi, I am wondering if there are any pc programs out there that I can use to monitor my household (sinewave) power. Thanks
  2. jadnashua
    What aspect do you want to monitor? Voltage, wave shape, current, frequency?
  4. r_2016
    r_2016 New Member
    May 25, 2007
    Voltage, wave form, freq. No current
  5. jimbo
    jimbo Plumber
    The big question would be WHY? The frequency is controlled to a very tight tolerance by the power company. Are you doing anything geeky at home which would somehow affect the waveshape??
    To answer your question, powerline voltage monitors are very common, with a recorder, and these days I would assume any model would have some kind of serial or USB interface.
    Frequency and waveshape are monitored with an oscilloscope, and a data interface should be available on those as well. Simple programs are undoubtedly available to display the data.
    As always, let your fingers do the walking>>> GOOGLE
  6. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    The guy on the following page shows tests of sine waves from various devices. Shows that not all sine waves are equal!
    He is using an oscilloscope. And for your PC to monitor this, you would need some sort of device to test with which would connect to your computer as well as the software.
    Basically the computer has no "direct testing" connection to the power.
    Observations on the quality of power produced by various backup devices...
    http://www.jkovach.net/projects/powerquality/
    Oscilloscope...
    [​IMG]
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Your tax dollars already paid for these kind of stats.
    Prying them out of PoCo is another thing altogether.
    I once saw a chart of NYC power. They had the envelope of 1/day, 1/week, 1/month transient magnitude and duration. Newspapers get this kind of info way easier than us peasants.
    Power quality is worse in FL or the Ozarks.
    http://books.google.com/books?id=SY...ahqMEB&sa=X&oi=book_result&ct=result&resnum=3
    But, yeah, what question are you hoping to answer?
  8. hj
    sine wave
    He may be trying to replicate one of the "power saving" devices that purport to condition the sine waves to "equalize" and "eliminate" the wasted power in your home.
  9. r_2016
    r_2016 New Member
    May 25, 2007
    What I want to do is monitor the incoming power from the electric company. Sometimes at my house we get voltage sags and spikes, so I want to be able to monitor it with some kind of program that will create log files so I can keep an eye on things.
  10. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    The more level of detail you want, the more it will cost. Resolving a 1 µS spike needs a bandwidth of at least 350 kHz.
  11. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    I once wrote a program that uses the PC sound card and a AC wall wart and a resistor divider, however most sound cards have a bit of phase distortion at 60hz.
    As for better equipment there are lots of USB based scope boards. Most of the scope boards accept low voltage voltages. You can drop the voltage using a AC output wall wart or by using a 24volt "control" transformer.
  12. Billy_Bob
    Apr 2, 2008
    Actually large computer facilities want "clean power" and do so with a large "online" "true sine wave" UPS system.
    And these log all "power events" which would be anything with the power which is not as it should be.
    I've seen these and they were recording events at least once an hour. Sometimes every half hour.
    I don't know if smaller UPS units would have the detailed logging abilities of these larger units or not? But these might do what you want.
    (And a UPS is an "Uninterruptible Power Supply")
  13. hj
    power
    If all you want to do is register the voltage coming in, there are all kinds of recording meters which make a continuous log on a circular disc. The particular meter will determine whether the disc records a 24 hours or 7 days period. But I don't know how the knowledge will help you, because whatever your incoming power is, that is ALL that the power company can/will provide, and you will have to live with it.
  14. Bobelectric
    Bobelectric Electrical Contractor
    Feb 16, 2009
    Eighty Four,Pa. 15330
    With that,I'm going to close this thread.
  15. sawdust123
    sawdust123 New Member
    Jul 25, 2009
    Audio Precision has a device called the ATS1 or Portable 1 that will show you voltage frequency and the distortion levels of the incoming sine wave. Of course, it does a lot more too but you would only care if you were an audio guy. They sell for several thousand dollars.
Similar Threads: Sine wave
Electrical Forum discussion & Blog Ignorant question, business replacing receptacles and switches. Oct 28, 2013
Electrical Forum discussion & Blog New to the business Nov 15, 2010
Electrical Forum discussion & Blog Over The Range Microwave Light bulb....... May 2, 2014
Electrical Forum discussion & Blog Wiring for hood and microwave Nov 14, 2010
Electrical Forum discussion & Blog Kitchen otr micro wave Aug 31, 2010
