Simple Question 5600 Econominder
Discussion in 'Water Softener Forum, Questions and Answers' started by gizzy, Jan 16, 2011.
  1. gizzy
    gizzy New Member
    Jan 16, 2011
    Michigan
    My softener runs every 5-6 days. It needs to run every 2-3 days. If I manually regenerate, everything is fine. How do I get it to run more often?
    The manufacturer website is very vague on this. Help!
    -gizzy
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Is it a meter or day?
    In the lower right hand corner is either a 12 day wheel or a wheel that goes from 0-21 that is a gallon counter..
  4. JKERN
    JKERN New Member
    Jan 12, 2011
    Manager and Tech of a Water Treatment Company
    Artesia NM
    I would guess that yours is a metered since econominder is generally referring to the metered 5600. Trick your unit by turning the capacity down. You need to figure out your gallonage usage first and then turn it to whatever that usage is in 2-3 days. On the other hand is that if this unit was set correctly for your water makeup and usage this is probably an indication that something is not working. How old is your unit and are you sure it was set properly at the initial startup?
  5. Gary Slusser
    Retired
    If there is nothing wrong causing hard water breakthrough before regeneration, you can click the link in my signature to learn how to determine when it should regenerate.
Similar Threads: Simple Question
Water Softener Forum, Questions and Answers Idea for simple air gap for softeners and backwashing filters Feb 28, 2016
Water Softener Forum, Questions and Answers Simple carbon filter idea Feb 20, 2016
Water Softener Forum, Questions and Answers New Softener Questions Yesterday at 10:41 AM
Water Softener Forum, Questions and Answers Carbon backwash system with chlorine question Sunday at 8:03 AM
Water Softener Forum, Questions and Answers Question about new softener and Drain Install Mar 14, 2017
