TvilleRider
I am replacing the copper plumbing in my split level home with expansion PEX. My sillcock is ~60 feet from the 3/4" well feed line. I was planning on running separate, valved hot and cold lines to the sillcock and then tee them together to enter a single handled sillcock. I will be running 1/2" hot water line. As I would want more pressure with the cold water, is there a difference in water pressure or volume at the sillcock discharge by running 3/4" the entire ~ 60 feet then reduce to 1/2 " at the sillcock versus running 1/2" pipe the whole distance from the 3/4" water feed? And I can't use two handles for separate hot and cold as there is already a mounting block on the vinyl siding for a single handle sillcock. Thanks
