Shut off valve for wall-mounted faucet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Boo, Aug 18, 2010.
  1. Boo
    Boo New Member
    May 29, 2007
    California
    Just wanted to confirm that a shut-off valve is required when installing wall-mounted bathroom sink faucet. I'm quite sure it's "yes," for obvious reasons (working on plumbing without having to shut off water main), but why aren't they required for pot-fillers over the stovetop - or are they required there, as well? Haven't decided whether we're going with a true vanity/vessel sink combo (whereby a valve wouldn't show) or a pedestal sink - then we have to pick an attractive vessel sink drain/shut-off kit.
    Thanks. :eek:
  2. Boo
    Boo New Member
    May 29, 2007
    California
    Oops...once I posted this, I got some other hits with similar question. I'd be interested in feedback nonetheless!
  4. jadnashua
    Not sure if it is required, but it is sure a lot more convenient!
  5. hj
    I have NOT installed any so far, and no inspector has even asked for them. My opinion they are no different than a tub/shower valve which also do not have them.
  6. Boo
    Boo New Member
    May 29, 2007
    California
    Thanks! That's our rationale for not installing one.
  7. Ian Gills
    Jul 24, 2007
    USA
    I have fitted shut-offs to my tub and shower and I'd probably add them to that sink as well. Just 'cos an inspector does not ask for them, doesn't mean that they are a bad idea.
    If all I did was the minimum to keep the inspector happy, my house would be falling down!
  8. Boo
    Boo New Member
    May 29, 2007
    California
    We usually do more than is minimally required in our home improvement projects, but I just can't seem to find a shut-off valve that doesn't look like it should be hidden under the toilet or behind a cabinet! With all of the high-end improvements we've made, I'd like it as clean-looking as possible. But your point is well-taken.
    Thanks everyone for your advice!
  9. hj
    Very FEW installations have "valves fitted to the tub/shower valves". They either come with integral stops, and those are few and far between except for certain multifamily installations, or they do not use them. I cannot remember the last one I installed which had integral stops. But I DO remember the last one I worked on which had integral stops which were inoperable, which is usually the case.
  10. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    I pipe from the wall mount faucet down and turn the piping out high under the cabinet/ counter, then install male adapters (either sweat or compression) after the cabinet/counter is installed, then connect with a flex just like a reg faucet. It is very convenient and as long as you have your elevations down you can make it look very neat/ proffesional.
  11. Ian Gills
    Jul 24, 2007
    USA
    They do some nice looking angle stops as well. I like the ones Terry uses on here, but I can never seem to find them.
    For the tub/shower I just solder on a couple of Apollo ball valves leading up to the valve, all hidden by the access panel.
Similar Threads: Shut valve
Plumbing Forum, Professional & DIY Advice PEX home run manifold system shut off valves Yesterday at 7:28 AM
Plumbing Forum, Professional & DIY Advice Zone valve clunks shut Friday at 7:58 AM
Plumbing Forum, Professional & DIY Advice Help with replacing shut-off valve Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Shutoff Valve Won't Open Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Turned one shut off valve now there is NO water in bathroom sink. HELP Dec 24, 2016
