Showerhead pipe faces up after remodel
Discussion in 'Shower & Bathtub Forum & Blog' started by rox05, Apr 9, 2005.
  1. rox05
    rox05 New Member
    Apr 9, 2005
    We recently did a remodel, and I inserted the new angled pipe into the wall for the shower Head. But when the pipe is tightened to tight, it is facing up toward the ceiling, instead of down into the shower. I tried adding extra wraps of teflon tape, but it still tightens up at about the same angle, facing up! The pipe is bright (gold-like finish) brass, and it is going into a Cast iron female thread in the wall. Any looser and it leaks. Scared to go any tighter, I'm afraid will rip the pipe mountings off in the wall.
    Do I have to find another short showerhead angle pipe with the thread starting at 180 degrees to the one I have?
  2. hj
    shower arm
    There is no "standard" as to where the thread starts on the shower arm. It is threaded and then bent so it could start anywhere. If the elbow is going to break in the wall it is not secured very well. A plumber would just tighten it to the proper location by putting more torsion on it.
  4. rox05
    rox05 New Member
    Apr 9, 2005
    well, I can't take a chance of ripping the fitting of the studs, it only has plastic (impervious to freezing) flexible line going down to the shower faucet. So I think I am going to put the pipe into a 1/2 inch threading die and cut another 1/2 turn of thread onto it. Then it should tighten up in the correct position.
  5. mrjetskey
    mrjetskey New Member
    Apr 11, 2005
    Texas
    That won't do a thing if your problem is inside thread that is corroded at that point.if you cant clean out the the coupling in the wall threads,which with a wire toothbrush sized brush or a dremel fitted with wire wheel,you might be able to file a half thread off of the new goose neck ,then instead of btm. out against the corroded threads in the wall coupling it will turn another half turn.If you cut more threads on gooseneck and the problem is corrosion in wall coupling you will still either btm out at same place or create a leak with another half turn,try cleaning first then filing gooseneck if you have to.JMHO but it worked for me!
Similar Threads: Showerhead pipe
Shower & Bathtub Forum & Blog How can I avoid a leak from hidden flexible Handheld showerhead hose in a tub? May 22, 2014
Shower & Bathtub Forum & Blog Never ending leak on showerhead... Dec 17, 2013
Shower & Bathtub Forum & Blog Dual showerhead question Apr 24, 2013
Shower & Bathtub Forum & Blog How to increase water pressure/flow in showerheads Feb 9, 2013
Shower & Bathtub Forum & Blog Raise showerhead Feb 8, 2013
