shower water wont turn off
Discussion in 'Shower & Bathtub Forum & Blog' started by asuss06, Jul 3, 2009.
  1. asuss06
    asuss06 New Member
    Jul 3, 2009
    I've got a steady-stream leak from my tub faucet. it's a 3 handle setup (hot, cold, diverter). ive replaced all 3 valves, gaskets/washers, i even replaced all three seats - or whatever you call them - that the valves screw into. it helped for about 2 days, but now the leak is a steady stream again and every day it gets worse. ive been told that i should get rid of the 3-knob setup altogether, and will do so next week. but why is it SO BAD now and what can i do in the meantime? this leak is rediculous and it wont stop!!!!
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    It's not put together right. The seats (rubber) are torn or something is not assembled correctly. Do you have time to tear into it again¿ Plumbers grease might help the reassembly.
  4. asuss06
    asuss06 New Member
    Jul 3, 2009
    thank you. you were right. things were not seated as well as they should have been and i think the grease did help a little too. its 90% better and that'll be fine till i redo the whole thing next week. thanks again.
Similar Threads: shower water
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Water runs from handheld and wall shower same time Oct 23, 2016
Shower & Bathtub Forum & Blog No water in shower and tub but water everywhere else in the house Sep 23, 2016
