Shower valve shut-offs necessary?
Discussion in 'Shower & Bathtub Forum & Blog' started by dakotakid, Jan 14, 2010.
  1. dakotakid
    dakotakid New Member
    Jan 14, 2010
    Photographer
    Rochester Hills MI
    I'm remodeling two bathrooms consecutively, and have the common wet wall between them open. The master bath has a shower only, with no access to the back side of the valve and drop-ear when tiled. Likewise, the bathtub/shower in the second bathroom has no easy access to the back of the valve.
    Is there any point to installing inline shut-off valves in addition to the screwdriver shutoffs on these valves? I plan to leave access to behind the lav in both of the bathrooms, and could install small ball valves that could be shut-off in an emergency to allow the rest of the system to stay active. Or is this gilding the lily?
    I'm using Danze valves with integrated screwdriver shut-offs, but from what I've read, most screwdriver shut-offs typically calcify and freeze shut down the road, when you most need them.
    What do y'all think?
    TIA
  2. PlumbPowerHouse
    PlumbPowerHouse Plumber
    Dec 10, 2009
    South Carolina
    I would go with the ball valves if your going to allow access. It will be easier and you won't have to deal with the stress of having to worry about the screw shutoffs. As a plumber, we usually don't put shut offs on a shower unless requested. I would do it with ball valves, that's your best bet.
  4. hj
    valves
    YOU are being paranoid. At least 99% of tub and shower valves are installed without ANY secondary shut offs, not even integral stops, and they manage to survive quite well, thank you.
  5. dakotakid
    Jan 14, 2010
    Photographer
    Rochester Hills MI
    Thanks guys! I am a bit paranoid, but one of these valves needed to be replaced about 12 years ago (house is almost 50 years old) and it was murder going through the mud wall and tile to get to it. The access will help that some, so maybe the extra valves are extraneous. Chances are any major work would need the main shut off anyway. Is that a fair assumption?
  6. hj
    assumption
    Your assumption is correct, and even a minor repair is usually easier to do by turning off the main valve.
    1. Most valves can be repaired without removing the trim plate, so the plumber would either NOT know the integral stops were there, or would not want to bother accessing them (my feelings towards them) even if they did work.
    2. The plumber might not know about your added valves so he would shut off all the water anyway.
    The only time the integral stops would have any real benefit is if you had a major catastrophe and had to shut the shower valve off for an extended period while you locate parts for it. Which could happen with a Danze valve.
Similar Threads: Shower valve
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
