Shower Plumbing Question
Discussion in 'Shower & Bathtub Forum & Blog' started by az1324, Nov 18, 2008.
  1. az1324
    az1324 New Member
    Dec 30, 2005
    I'm replacing a tub with a shower and plumbing the drain. I am removing the reducing tee and using a 2" drain instead of the 1.5". The drain, however is situated directly above a joist and there isn't room to place the p trap in that spot. The joist has already been notched, and I do not wish to notch it any further to avoid completely compromising its integrity.
    So can I just elbow over and up from the p trap using 2 90 deg fittings? Just want to confirm that this is ok for proper drainage.
    Edit: Ok that's not really helpful as an elbow takes up just as much room vertically as a p-trap. What I'm gonna do is 22 up from the tee and 22 back to horizontal then the p trap will be raised above the joist and be just low enough to make the connection. Sorry for wasting a thread. Delete if desired.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yes, you can offset the drain to the trap as you indicate.
  4. hj
    drain
    A 45 and a street 45 might be better.
Similar Threads: Shower Plumbing
Shower & Bathtub Forum & Blog Two Shower Heads, No tub. Simple Plumbing ??? Wednesday at 12:50 PM
Shower & Bathtub Forum & Blog Shower remodel plumbing dilemma Dec 8, 2015
Shower & Bathtub Forum & Blog Finish Work Shower Plumbing Fixtures Aug 15, 2015
Shower & Bathtub Forum & Blog Custom Shower Plumbing Rough-In Advice Needed Jul 8, 2015
Shower & Bathtub Forum & Blog Help with Large Master Shower plumbing Mar 17, 2015
