Shower Pan Installation
Discussion in 'Shower & Bathtub Forum & Blog' started by elgato, Jan 26, 2007.
  1. elgato
    elgato Member
    Jan 20, 2007
    Phoenix, AZ
    I just received my 54x34 Swanstone pan. I am surprised at how lightweight it is. I cannot see how it could be installed without a mortar bed.
    http://i38.photobucket.com/albums/e146/haiptyg/P1010098.jpg
    The grid ranges from approx 1/2" at the edge to o" at the center. It looks like a challenge to spread the mortar so that it evenly fills most pockets.
    Second Question.
    These photos are of the 8"x 16" hole in the slab for plumbing. Originally it was filled with dirt but it did not provide adequate support in the center. The old pan cracked near the drain.
    http://i38.photobucket.com/albums/e146/haiptyg/P1010097.jpg
    http://i38.photobucket.com/albums/e146/haiptyg/P1010096.jpg
    Any recommendations on how to approach this? The Swanstone pan looks like it should have support as close to the center as possible.
    Thanks
    Tom
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Wrap the pipe in a bit of foam where it comes through the slab or sleeve it with a piece of 3" PVC/ABS...
    Back fill the hole with dirt to 4" from the surface...
    Repour around the tailpiece to give your pan support.
  4. elgato
    elgato Member
    Jan 20, 2007
    Phoenix, AZ
    Would you suggest repouring with something easier to remove than concrete?
    If so, what?
    Also, would it be acceptable to backfill with sand?
    Thank You
    Tom
Similar Threads: Shower Installation
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog Steam Shower Generator Installation Nov 22, 2016
Shower & Bathtub Forum & Blog Shower arm installation for rain head Jul 14, 2016
Shower & Bathtub Forum & Blog Is there a problem with this bath/shower installation? Mar 21, 2016
Shower & Bathtub Forum & Blog DIY SHOWER MASTERPIECE: Video Guide for Shower System Installation Aug 14, 2015
