Shower layout / joist interference
Discussion in 'Shower & Bathtub Forum & Blog' started by jch, Aug 28, 2008.
  1. jch
    jch Member
    Jan 3, 2006
    Victoria, British Columbia, Canada
    I'm redoing a bathroom and replacing a clawfoot tub with a shower.
    My designer has spec'd a 36" W x 50" L shower area along one wall with a 1-foot neo-angle corner.
    However, the floor joist runs lengthwise under the proposed shower area at 18" from the wall (right where I would want to put the drain).
    How do you normally deal with this sort of problem?
    - mount the drain off-center? (say, 20" from the one side wall and 16" from the other)
    - make the shower area skinnier so that the mid-point no longer falls on the joist?
    - move the shower area out from the wall a bit (say with an extra 2x4 ledge along the long wall) so that the newly-centered drain now misses the joist?
    - something else??
    I was hoping to use a Schluter kit for the base, but any non-standard drain placement is going to make that impossible.
    Advice?
    .../john
  2. jadnashua
    It's easier if you keep thoughts on one project in one thread. You could build a header and box out the joist area enough to allow the drain where you want it. A shower does look better if the drain is centered, but it doesn't have to be. I'd probably just buy the Kerdi and drain, then make a mudbed and put it slightly off-center and clear the joists. Deck mud is intimidating, but not all that bad. It's sort of like working with wet beach sand if mixed right.
  4. jch
    jch Member
    Jan 3, 2006
    Ooops! I thought this might be a general knowledge type question that others could use in the future....
    Interesting--for some reason I hadn't thought of doing that. This is a reno'd attic, so the floor joists are the original 2x4's sistered with new 2x10's. In that area, there's a 2" gap between them (due to staggered overlapping) so I'd have to think about how I'd actually get a header in there (the sistered 2x4 and 2x10 are not touching in the area where a header would go).
    Thanks for the suggestion.
Similar Threads: Shower layout
Shower & Bathtub Forum & Blog Valve layout for tub/shower?????????? Jun 11, 2016
Shower & Bathtub Forum & Blog Shower remodel layout. Two Moen Positemp Valves Jun 5, 2016
Shower & Bathtub Forum & Blog Shower Design - How to layout six body jets Jul 7, 2014
Shower & Bathtub Forum & Blog Bath and shower layout too unconventional? Apr 30, 2012
Shower & Bathtub Forum & Blog Please help me with bathroom shower plumbing/layout questions! Feb 14, 2012
