Shower Drain Too High
Discussion in 'Shower & Bathtub Forum & Blog' started by tlcfromep, May 22, 2005.
  1. tlcfromep
    tlcfromep New Member
    May 22, 2005
    OK, so I don't have a lot of experience with plumbing so I hope there's a simple fix for this and I just don't know it! I just bought a house and the previous owner had the bathroom completely redone. There was no shower there three years ago so I know everything is new. The problem is that she tiled the floor once and then tiled over it...now the new tiles will not stay in place. Every time I use the shower (which has been about 5 times...thank goodness there's a separate tub!) grout and adhesive come up between the tiles. I would most like to remove the entire second layer of tiles (because the first layer is the exact same tile) but then the lip of the shower drain is about 1/4" above the floor level, meaning there'd be water standing on the floor. Any suggestion, anyone? Thanks.
  2. hj
    tile
    I don't know, but if the shower is less than five years old and has had two layers of tiles in it already, I would suspect that the entire installation is a DIY "nightmare" and may have to be torn out and redone.
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Yesterday at 4:17 PM
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
