shower drain material: ABS or cast iron?
Discussion in 'Shower & Bathtub Forum & Blog' started by Emma3, Jan 30, 2008.
  1. Emma3
    Emma3 New Member
    Aug 30, 2007
    Washington
    Just had rough-in completed for new shower. The plumber is about to install the actual drain fitting onto the ABS drain pipe, and I need to choose between an ABS drain (with chrome plate stainless, I believe), and cast iron. The cast iron is maybe $200 more.
    This will be a custom-tiled shower and will be used regularly, so I definitely don't want to cut corners, but is the cast iron really necessary or worth the extra cost?
  2. jadnashua
    I'd go with the abs. Just like most things, there's good quality and marginal. You don't want the least expensive item, regardless of the material. The quality of the parts you see is important and for that part, thicker material, higher quality plating, non-rusting materials, is the big thing.
  4. Emma3
    Emma3 New Member
    Aug 30, 2007
    Washington
    manufacturer for ABS drain?
    Ok, makes sense. Can you recommend a brand for good quality ABS drains? The plumber made it sound like we had two options -- the indestructible cast iron, or flimsy ABS. Unless I can compare some different options in the same material, I won't be able to make sure he's using something decent.
  5. hj
    drain
    The ABS drain that glues to the pipe will be the least likely to cause any future problems.
  6. jadnashua
    Sorry, don't have any ideas on brands. The showers I've done used the Kerdi system, which has it's own special drain. It must be used with the system, as it uses a surface membrane rather than a liner. I think it makes a superior shower, but a conventional one, done right can last as long. Check out www.schluter.com for the Kerdi system for reference.
    You may want to ask this question over at www.johnbridge.com. Those guys live tiling and showers so you'll get more exposure on this type of question. They probably have some recommendations in their library (liberry).
Similar Threads: shower drain
Shower & Bathtub Forum & Blog Cast Iron Shower drain on concrete Yesterday at 2:58 PM
Shower & Bathtub Forum & Blog Odd Shower Drain Rough In Mar 5, 2017
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
