JDWellness
I have a self contained shower being installed up against an enclosed circular stairway. Originally the plan was to put the controller in the corner of the shower unit but the self contained unit has a flexible and curved plastic wall component there so it cannot accomodate a flat controller that needs a solid surface to connect to.
Is there a unit that houses the controller more on the inside of the shower than in the wall that I can use to address this space problem or is there another type of controller where the actual valve(s) are separate from the control handle so I can tuck the controller in the dead corner of the circular stairway where there is space, as there is not enough room for a traditional controller that would typically be attached to the side of the shower?
Thanks for your help!
