Shower arm installation
dogs01
I am installing a shower head/arm. I am unable to thread the arm completely in order to keep it at the angle needed. Is it ok for the arm to be somewhat loose? If yes, how can I check for leak?
Loose is not good! It could leak inside the wall and mess things up quickly.
Two things, either rotate it around further or try adding another layer or two of teflon tape. This takes some experimentation to get it just right.
AlwaysInHotWater
California
Not sure I would trust just putting more teflon tape on it. I believe in using plenty of tape but the pipe still needs to be tight especially behind the wall where you can't see a leak.
