Shower and hand held 3/4 valve
Discussion in 'Shower & Bathtub Forum & Blog' started by scooterbase 001, Dec 1, 2011.
  1. scooterbase 001
    scooterbase 001 New Member
    Dec 1, 2011
    Santa Clarita Ca.
    Will a 3/4 inch valve with 8 inch shower head and hand held work if I only have 1/2 inch pipe to it or should I run 3/4 all the way to the valve?
  2. jadnashua
    What is the gpm rating of each, and will they ever both be on at the same time?
  4. scooterbase 001
    Dec 1, 2011
    Santa Clarita Ca.
    I'm not sure what the gpm is, but it's an exterior valve with a n 8 inch rain head and all 3/4 piping from valve up to the head, I would think this would need a good volume of water to be strong enough.
  5. jadnashua
    Federal regulations restrict any single showerhead to 2.5gpm (this is measured at a specific pressure). So, if you only have two possible on at one time, a 1/2" line should be okay. If you want to add stuff like body sprays, or an additional head, it would not. If your house pressure is marginal, no supply will produce your desired effects. Don't expect high pressure out of a rainhead...it isn't very forceful.
Similar Threads: Shower hand
Shower & Bathtub Forum & Blog Single handle shower identification Jan 15, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog HIGH flow HANDHELD shower Dec 26, 2016
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Water runs from handheld and wall shower same time Oct 23, 2016
