Sheetrock or Mold-Tough on bathroom ceiling and how thick?
Discussion in 'Remodel Forum & Blog' started by mckeand13, Oct 29, 2008.
  1. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    I'm remodeling a bathroom in our house. Current ceiling is 3/8" sheetrock and 3/8" (plasterboard?) of plaster. There is also a soffit which I am taking down so it's easiest to remove the entire ceiling rather than match old with new.
    The bathroom is pretty small. I have to verify again, but if I remember correctly, rafters are 16" O.C.
    My question is, should I use Mold-Tough (greenboard) or regular sheetrock on the ceiling. Is there any reason to use 1/2" or 5/8"? I'm thinking the Mold-Tough since the ceiling is always the steamiest in the room. I do have a fan.
    Thanks.
  2. jadnashua
    Greenboard needs 12" support on a ceiling. 1/2" or 5/8" drywall is fine if you paint it well with a good paint. Use of an exhaust fan is recommended in any moist environment as well.
  4. mckeand13
    mckeand13 Engineer
    Jan 27, 2007
    Engineer
    Orono, MN
    The tech sheet from USG for the Mold-Tough shows a 24" O.C. max for both the 1/2" and 5/8" on a ceiling.
    Maybe I'm reading wrong, but see if you agree.
    I couldn't upload the file as it's a bit too large. Just replace the asterisks with home depot and you'll get there.
    http://www.*********.com/hdus/en_US/DTCCOM/HomePage/Know_How/Brand_Pages/Building_Supplies/USG/Docs/Mold_Tough.pdf
  5. jadnashua
    Generic greenboard isn't as robust as this newer stuff appears to be. Regardless, if you use a ventilation fan and have a good coat of paint, regular drywall will work as well. A good coat of paint prevents the moisture from penetrating, and if that's the case, what's underneath doesn't matter. Mold takes three things: spores, moisture, and food. Pick the right paint and you can eliminate two of the three. The paper of the drywall could be food, but only if it gets wet.
Similar Threads: Sheetrock Mold-Tough
Remodel Forum & Blog Bathroom remodel (sheetrock wall question) Mar 29, 2011
Remodel Forum & Blog Wall mount toilet to sheetrock?? Nov 9, 2008
Remodel Forum & Blog Painting Yellow board Sheetrock? Sep 3, 2007
