Sharkbite and hot water baseboard
Discussion in 'HVAC Heating & Cooling' started by rhg, Sep 18, 2009.
  1. rhg
    rhg New Member
    Sep 18, 2009
    New Jersey
    Hello to all. I have a hot-water baseboard in my 2nd floor master bath that I want to either move or remove entirely. It will be very difficult if not impossible to sweat new fittings from below. I thought about using Sharkbit connectors to attach the new configuration, but I see that they are rated for only upto 200F. My boiler hi-temp is set at around 210F. This baseboard is at the head of the zone and the pipe registers 209F on an infrared thermometer. Maybe this is a stupid question, but can I use Sharkbites on this baseboard? I know the system is low pressure so I thought I'd ask anyway.
    Another possibility: should I lower the temp setting on the boiler to 200F or will this screw up efficiency? Any ideas are welcome. Thanks
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    You can lower the boiler temperature setting to 180 and probably gain something in efficiency. As for the Shark Bites...I don't know.
Similar Threads: Sharkbite water
HVAC Heating & Cooling Radiant heat and domestic water on same system? Monday at 8:06 AM
HVAC Heating & Cooling Indirect Hot water is Yellow Feb 8, 2017
HVAC Heating & Cooling Circulated hot water pros and cons Apr 10, 2016
HVAC Heating & Cooling Adding inline filter between water heater and humidifier? Nov 6, 2015
HVAC Heating & Cooling Hot water baseboard heater in basement - install Oct 11, 2015
