Sharing a brine tank?
kozmic
Nevada
I'm installing a nitrate filter and a new water softener. They both have a brine tank. Is there any reason I can't use the same one for both? It seems silly to have two tanks full of salt water, and I could really use the space.
I presume that you can be sure that the cycles don't overlap by setting sufficiently different times? The cycles can run up to a couple hours if you do standard fill at the end of the cycle, and add maybe another 3? hours if you brine fill before the regeneration.
Do they both refill the same amount of brine? If not, the controllers would each need to be set to fill the tank before the regeneration, vs at the end of the regeneration.
I am not a pro.
kozmic
Nevada
I am assuming that the controllers fill till the float stops it, and draws based on time. I could mount both of the float towers in one brine tank, and just put them at the same level.
Most systems don't do that. The float is a safety float to stop filling in a failure condition. Then during brine draw, the brine is drawn until the brine has been sucked down.
