Sewer gas from stack, stinking out back yard
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by burleymike, May 2, 2011.
  1. burleymike
    burleymike New Member
    Nov 4, 2008
    Idaho
    We have been having an ongoing problem with sewer gas outside the house. Those cold winter days you can even see steam blowing out the roof vents. When the wind blows from the south the way the roof is the stink blows right down to the patio.
    Is there a check valve that can be installed on the roof vents? I thought about raising the vent height but I doubt it would help. Our chimney is already tall and the smoke gets pushed down to the ground. We have some big trees that create downdrafts. Any ideas welcome.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  4. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    I had this same problem. I installed an Air Admittance Valve (AAV) on the top of the 4 inch vent on the roof that is over the bathroom. The AAV allows air to go into the vent but does not allow it to come out. They are used inside of buildings instead of cutting holes through the roof or where you do not want the vent to show. When I was picking it out at Lowe's the salesman said it was not approved to be used outdoors. He said it would deteriorate and not hold up in the sun. I told him I do not care and when it deteriorates I will saw it off and put on another one. It has been up there for twelve years. There is a plastic screen around the edge that has started to fall apart. It has worked and there have been no odors at the back door or on my patio since I installed it. Mine is a Studor vent.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    I would not use a air admittance valve in this application.
    When sending water to a closed container it is very desirable for air to be able to escape...
Similar Threads: Sewer stack
Plumbing Forum, Professional & DIY Advice DIY Question: Replace Partial Cast Iron Sewer Stack May 19, 2015
Plumbing Forum, Professional & DIY Advice Stack pipe/sewer ? Aug 11, 2013
Plumbing Forum, Professional & DIY Advice replacing Cast Iron Stack with Pvc to Clay Sewer pipe Sep 4, 2011
Plumbing Forum, Professional & DIY Advice Cracked cast iron 4-way Tee in Vent stack/sewer drain in bathroom Apr 17, 2011
Plumbing Forum, Professional & DIY Advice ABS Sewer (Stack Pipe) Jun 28, 2010
