Sewager Ejector and Flexible PVC??
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by eddle6389, Feb 19, 2005.
  1. eddle6389
    eddle6389 New Member
    Feb 19, 2005
    Hello,
    I am in the process of installing my new Flotec Sewage Ejector Pump. I have an odd angle where my discharge line from my pump ties into my main 4 inch drain line. The builder has a 4" to 2" plug in the cleanout and I am tying in to that point. I can force the 2" lines together, but I don't get a complete fit. Is this OK or can I use a section of flexible pvc to make this connection? The specs on the flex pipe say it is rated to 100psi, but I'm not sure if you can cement it to rigid pvc.
    Question # 2 - How far should your vent pipe extend into your sump basin?
    Thanks in advance for your help.
    John
  2. hj
    pump
    Any "odd" angle can be connected using the proper drain fittings. Flexible PVC can be joined to rigid as long as your cement specifies that it is for flex pvc. The vent does not extend into the pit. It starts at the cover and goes up from there.
  4. eddle6389
    Feb 19, 2005
    Thanks
    Thanks for your quick reply. Would you reccomend using flexible pvc for a pressure application or am I better off working with the standard pvc?
    JOhn
  5. hj
    pvc
    I would use rigid PVC. The flexible material is thicker and the joints do not always handle pressure as well, but at your connection point pressure should not be a problem.
Similar Threads: Sewager Ejector
Pumps and Tanks Well Forum & Blog. Water is life. Open Spring Dog , Should I use? And Leather Packers in 2 inch ejector? Jul 21, 2015
Pumps and Tanks Well Forum & Blog. Water is life. ejector pump flowing back after 1 min Aug 18, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Can convertible pump ejector be mounted with short pieces of pipe? Jun 27, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Ejector Pump running in basement after water usage on main floor May 26, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Identify this square mass in old ejector pit Mar 23, 2014
