Sewage Pump stops with a THUD
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jdoll42, Jan 27, 2009.
  1. jdoll42
    jdoll42 Computer Systems Engineer
    Apr 4, 2007
    In Illinois near St. Louis, MO
    My sewer line leaves the house well above the basement floor. To compensate for this, there is a small pump in a sealed chamber that takes any water from the floor drain and pumps it up to the main sewer line. I recently had a flow-through humidifier installed. This causes the sewer pump to run several times a day. Everything is great, until the pump kicks off with a really loud THUD.
    Coming out of the sealed sump, there is a check valve immediately followed by a ball valve. Then there is about 6' of vertical pipe before it turns and flows into the main waste line. All of the pipe from the sump to the main waste line is 2" PVC. I'm pretty sure the pounding has to do with the check valve slamming shut. I'm really concerned about damaging the pipes. Does anybody have any suggestions? The slamming is driving my wife nuts...and you know if your wife isn't happy, nobody's happy!
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    That A.Y. McDonald valve is your answer!
    Good call cacher chick!
Similar Threads: Sewage Pump
Pumps and Tanks Well Forum & Blog. Water is life. Sewage pump or grinder pump Aug 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sewage Pump Question Mar 7, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Mud & Leaf problem - sump or sewage pump Dec 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Connecting a sewage pump Dec 30, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Correct forum for info on submersible sewage pump with grinder? Mar 28, 2013
