Sewage pump. Out of ideas... DIY new basement bathroom
Bets
Michigan
This is my spouse and I's first below-grade bathroom challenge. We've done pretty much every type of construction and remodeling except putting in a basement bathroom. And it's definitely kicking our butts! Any advice is appreciated.
Problem: We're putting in a basement bathroom (sink, toilet, and shower). Our main line runs from the stack into the ground. We tore up the slab and found out that the slope from Point A (where we want the bathroom) to Point B (main line) was not enough to allow for 1/4 inch per foot. It's practically even. In an effort to solve the problem, we went out and bought a sewage pump. Our goal was to run the sewage to the pump, then have the pump send the sewage horizontally to the main line. The horizontal run would be about 5 feet and a 1 foot slope. Well, after doing some Googling, I'm torn. People are saying that the check valve should be installed vertically. But what we really want is to do a 45 degree, attach the check valve, then continue to the main (see pic) horizontally. I'm torn because it has a lot of push power-- Everbilt 1/2 HP Sewage Pump, capable of 2" dia solids.
What are your thoughts? Is it okay to 45 degree? Suggestions appreciated.
FYI-- we're planning on burying the pump basin like normal, but sinking it a little lower and having a hatch area for maintenance. That's why there's that box area around it in the picture.
Bets
Michigan
Nevermind folks! I spoke with the manufacturer who verified that it is okay to bring it up, 45 degree, install the catch valve, then carry on horizontally. Just figured I'd post here for anyone else that may have the same question! I would still recommend calling the manufacturer of your particular pump and double checking what they're recommendations are.
quote; Point A (where we want the bathroom) to Point B (main line) was not enough to allow for 1/4 inch per foot.
I'm curious how you measured it, since point "A" would NOT be obvious until you knew how you were going to install the piping. How deep is point "B" below the floor?
Michael Young
North Carolina
DO YOU HAVE ENOUGH ROOM TO GET 1% OF FALL (approx. 1/8" per inch). If so, you don't need a pump
