service riser needs for an electrical service upgrade?
Discussion in 'Electrical Forum discussion & Blog' started by myladyfae, Feb 12, 2010.
  1. myladyfae
    myladyfae New Member
    Sep 14, 2009
    Boston
    We are currently looking at upgrading our electrical service into the house. One of our quotes came back and was very reasonable, but had something that made me pause. For the service riser (aerial) he is suggesting we replace the existing pipe and wires with a grey cable...no pipe.
    Does this seem right? Or at least, a good idea? I'm not worried about the asthetic really since its just a little cape...the cable barely goes 15 feet up and is screened by a bush half the way. The color will blend in too. But I am concerned about how good an idea it is not to have the cable protected by some sort of piping.
    could definately use some advice!
  2. Lightwave
    Lightwave New Member
    Aug 20, 2007
    Vancouver, BC
    You'll have to ask your local electrical inspector and power company to get a definitive answer whether cable is acceptable for service hookup in your area.
    Personally, I'd go with conduit (pipe) even if cable is legal. There's more than enough ampacity in a service drop to ruin your day several times over. Every extra bit of protection between the service conductors and carelessly swung hedge trimmers (etc) is a good thing.
    [video=youtube;fCZOd2MPoMY]http://www.youtube.com/watch?v=fCZOd2MPoMY[/video]
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    If it is code compliant in your area it is FINE. I bet 99% of the homes in your area have it, don't they.
  5. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    It may be legal in your area but in my opionion it's a horrible idea.
    It has never been allowed in my area.
    Again, it is my opinion is that unprotected, unfused wires/cable should never be strapped to a house.
  6. Jim Port
    Jim Port Electrical Contractor
    Aug 22, 2009
    Maryland
    SE cable is commonly used in the Mid Atlantic area with no problems.
  7. myladyfae
    Sep 14, 2009
    Boston
    it is code compliant, but honestly most homes around here DO have conduit. At least the newer installations do. There seems to be some contention on whether it is a bad idea or not....hopefully a few more people weigh in so I can make a decision with a clear concience!
  8. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I would say that installation in conduit is safer given the protection provided by the conduit. Without the conduit there is a greater risk of the cable being damaged and the results could be very bad.
  9. Ian Gills
    Jul 24, 2007
    USA
    My rambler has its original SE cable without conduit and has been fine for 60 years (although needs to be upgraded soon). The only ones in conduit around here are those cables that go through portions of the roof.
  10. ballvalve
    Dec 28, 2009
    northfork, california
    Ever see what a 4 year old can do with a step ladder and dads corkscrew? What, is pipe that expensive these days? Cut your seatbelts out of your car and pulled the air bag fuse too? Put knob and tube wiring in on your remodel? They make half pipe with a nail flange that might save some lives cheap.
  11. myladyfae
    Sep 14, 2009
    Boston
    well the contractor is charging 250 extra to install with conduit. BUT, the more I've thought about the bushes in front and looked at the other houses in the area, the more I feel you are probably right...it's best to just go with the extra. Although I may try to talk him down on the cost for it...seems a little excessive when I could buy it from graybar for 50 bucks or so.
    Now I just need to figure out how to cover the hole left in my siding when they move the meter up 3 feet!
Similar Threads: service riser
Electrical Forum discussion & Blog 200-amp Service to 100-amp Service Sep 21, 2016
Electrical Forum discussion & Blog 200 amp service split between two panels Mar 14, 2016
Electrical Forum discussion & Blog New Electrical Service and meter for detached garage Aug 4, 2015
Electrical Forum discussion & Blog Service Upgrade & Sub Panel Installation Apr 17, 2015
Electrical Forum discussion & Blog What is the new year bringing, especially in residential, especially in service panel Jan 5, 2014
