septic with sump pump question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ruffy48, Aug 8, 2005.
  1. ruffy48
    ruffy48 New Member
    Aug 8, 2005
    I just moved into a house in the country which has a strange setup. I cannot believe this is right but it was approved by FHA.
    This house has a well (which is fine) and a septic tank (also not a problem). Before I got the loan from FHA, they made the previous owner install a sump pump in the basement. The weird thing is, everything except the commode now drains to the sump. And I mean everything........sinks, tub, washing machine! And to boot, it drains into the pasture on the next property. The old guy doesn't care, but I'm kind of concerned. What happens when I go to resell the house?
    Am I wrong in thinking this is a problem in Pennsylvania? This can't be normal.........can it??
Similar Threads: septic sump
Plumbing Forum, Professional & DIY Advice Septic system-- to what degree do I try to avoid a pump in the system? Mar 17, 2017
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Roots growing into septic tank Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Help with septic drainage field possible leakage on hill Sep 14, 2016
