Septic system sizing = GPD needed
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ecofarmer, Apr 16, 2009.
  1. ecofarmer
    ecofarmer New Member
    Apr 15, 2009
    I’m working on building my shop / office for my farm. I’m about to go apply for a permit on the septic system but I need a design. The building has 2 full bathrooms, a sink for a food fixing area (fridge and microwave), and 2 utility sinks. The floor drains, utility sinks, and showers are on a gray water system.
    Code calls for 2 tanks and an aerator (sp) in the second tank for houses. I can skip the aerator for this because this building will not see continues use. We do have to get a pump done every 5 years by code.
    I’m thinking I should go with 1000 primary and a 500 secondary tank witch would be smallest by code I could use. I’m planning on using the half moon plastic leaching field system also. Were a family of 5 and can see us spending time around the shop in the summer a few days a week so I’m sure it will be used for the bathrooms and for cleaning up after being out side all day long. I can also see family gatherings a few times a year.
    I’m thinking 3.5 gallons to flush and wash your hands. If every one went 4 times in 8 hours would give us 20 rounds on a normal day. So 70 gallons a day for normal times but for family get-togethers I would say 57 rounds in the bathrooms witch would put us at 199.5 gallons per day, but this would only be a few times a year.
    Should I use 100, 150, or 200 as my number for sizing this systems leaching field? I do not want to have issues with this down the road. I want to do it right the first time.
    Is there a better way to come up with this number (they want to see how I got the number)?
    Any other suggestions that everyone over looks?
  2. hj
    Size
    Septic systems are seldom sized by guesswork. They are sized by usage AND a factor called seepage. The ONLY way to get a handle on seepage is with a percolation test, usually administered by a certified septic system contractor or plumber. That is the number they will want to see when they evaluate your seepage field to see if it is the proper size.
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You will need a plan that has been drawn and certified by an engineer. Your local building department will not accept anything without an engineers stamp that has been accepted by the state first.
  5. 3m
    3m New Member
    Mar 3, 2009
    NY
    It depends upon where you are, The county I live in requires a perc test to see how much field bed you will need depending on the number of bedrooms in the house.When you go to get the permit the building inspector doesnt even look at the perc test but says FOR A 2 BEDROOM HOME 500 LINEAL FEET OF FIELD BEDS ARE NEEDED, thats 5 100 foot runs. In reality most field beds are figured on the bedrooms and the amount of waterflow per day and the perc rate of the soil determines the square feet of field bed needed
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Same here: The size of the tank(s) depend(s) upon the number of bedrooms, then the size of the drain field additionally depends upon percolation testing to see what drainage your soil can actually handle.
    The plastic chamber system as a drain field is definitely better than the old-style, rock-filled trenches, and sometimes only half as much is needed.
    Do not make the mistake of installing absolute minimums now only to later have trouble when usage changes or when trying to sell the property.
  7. mcrandi
    mcrandi New Member
    May 2, 2009
    however, it is very important to use properseptic tank cleaning mechanisms to improve you garden health
Similar Threads: Septic system
Plumbing Forum, Professional & DIY Advice Older septic system runs fuller than it should; how to clear out sediment from lines? Dec 7, 2016
Plumbing Forum, Professional & DIY Advice Drainfield septic system question Mar 19, 2016
Plumbing Forum, Professional & DIY Advice Adding a bathroom - but can't reach exisiting septic system Jul 15, 2015
Plumbing Forum, Professional & DIY Advice Is it okay to have an in-sink disposal with a septic system? Jul 13, 2015
Plumbing Forum, Professional & DIY Advice Broken septic system inspection port Jul 12, 2015
