Septic Pump Help
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lauren, Sep 4, 2010.
  1. lauren
    lauren New Member
    Sep 4, 2010
    Murfreesboro, TN
    My husband and I are building a house in a heavily wooded and hilly area. Our septic site is uphill from the house site. We do not want to move the house so it seems our only option is to use a septic pump. I've been searching this forum for awhile trying to find answers to my questions, but I've had no luck.
    What size (HP) pump do we need for a 1000 gal tank? The line will be about a 3' rise over 100'. What brand do you guys recommend? What GPM flow? I'm just learning this stuff so I'm a bit lost! Any information would be greatly appreciated.
    Cheers,
    Lauren
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    Zoellers web site will give you the pump sizing chart and the performance curves that you need to properly size the pump. If the system handles all the effluent in the house I recommend two pumps, one for a back up with alarms and switching so that if the pump fails on the weekend or a long vacation you still have service. Liberty also makes a good system.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Seeing as your whole house will be on this system I would recommend a duplex pump system with alternating pumps and an alarm.
    This will give you redundancy and notification if a problem arises. There is nothing worse than than a failure of a single pump system on a Saturday afternoon on a holiday weekend...
    http://www.zoellerpumps.com/ProductBenefit.aspx?ProductID=72
  5. ballvalve
    Dec 28, 2009
    northfork, california
    Be sure to put your septic tank at the house site, and pump just effluent up the hill. Now you saved a thousand on the pump and you can set the pump in a Orenco [or other] filter screen within the second chamber in the tank. I think one pump is plenty with that set up as long as you have a good high water alarm or two. Forward thinking septic installers will give you 50' of leach pipe on the outlet end of the tank for the day that the pump fails - no back up into house and gives time to swap the pump without wading in a mess.
    Be certain your installer knows the parameters of the particular septic tank in terms of setting the high and low float height. You have to pump within the tank MFGR's specs. Also install a LARGE size riser with lid, so a person get step inside and work on the checkvalves and unions and floats without another guy holding him upside down by his ankles.
Similar Threads: Septic Pump
Plumbing Forum, Professional & DIY Advice Septic system-- to what degree do I try to avoid a pump in the system? Mar 17, 2017
Plumbing Forum, Professional & DIY Advice Septic tank/sewage ejector pumps Dec 21, 2015
Plumbing Forum, Professional & DIY Advice Basement Septic Pump System failure - UPDATED with a new question. Jun 23, 2014
Plumbing Forum, Professional & DIY Advice Complex Question About Pumping Septic Feb 28, 2014
Plumbing Forum, Professional & DIY Advice A good septic pumper-person? Aug 18, 2012
