Septic cleanout
rdean
I have a need to put a septic cleanout in the yard. The real reason is the occassional dumping of the travel trailer tanks. Spoke with the inspector. He said I could not put in a connector to dump, but he would not have a problem with a cleanout. Use it however I needed to.
So I dig down and use a snap cutter on the cast iron. Install a wye using Mission no-hub's. Should I put gravel around this before replacing the dirt? On the ground surface I intend to use one of those boxes with the lid so I will not have a problem with the mower. Have I left anything out?
Thanks for the input
rdean
chemicals
Don't use the stuff. I use a natural product similar to what I send into the septic periodically. I do not know why some have all the fuss over their black and gray tanks. I treat it like my septic, keep water in the traps and toilet and we have no odors. I watch what passes when I dump and it is similar to what I have seen others dump that are heavy with chemicals. So why spend all the extra $$$. Besides the chemicals would go into someone else's septic. Why would I want to do that?
County tried to strong arm everyone around me to put in sewer about 10 years ago. Most paid out the $$ and complied. In fact some are just now paying it off. I was told if I need any major repairs they will condem my septic and force me to go to sewer. So I take care of it. Wash water is recycled to the gardens. Only thing down the chute is what needs to go down.
To go from where I park the trailer to where I will need to place the cleanout means I will need to use one of those macerator type of hoses. All the better I think. It might help that #2 is off limits to the males of the family. :D unless it is a dire emergency! Now that would be a totally different situation.
With that all said do you think the installation is correct?
