Second Opinion Needed
Discussion in 'Pumps and Tanks Well Forum & Blog' started by scottj, Jan 13, 2008.
  1. scottj
    scottj New Member
    Jan 1, 2008
    I have a standard setup with a Gould J5SH shallow well pump and a Well-Rite pressure tank. The problem is that the pump is continously running. I have a new pressure regulator, working properly. I have cleaned the jet pump nozzle. I have checked the pressure tank pressure and added air to set the tank pressure to 28 PSI. The initial pressure was 0, so I expect I have a leak in the tank bladder and will be replacing the tank. But, what to do with the pump? Even if I precharge the pressure tank to 28 PSI, I cannot get the system pressure to go above 45 PSI. The pump just runs and will not shut off. There are no water leaks in the system. My initial thoughts are that the pump has seen its better days and should be replaced. Replacing the tank is going to be a bear. Replacing the tank and using the old pump just to find out I have to go back in with a new pump is what I am trying to avoid. Any second opionions based on experience?
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Maybe the pump is wearing out, impeller-wise. You can go with lower pressure settings, just to see what the pump can produce.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Sometimes some crud gets caught in the nozzle which is usually accessible for cleaning through a removable plug on the centerline at the suction side.
    Go to Page 3 of the document at the link and see the location of the nozzle clean-out plug and the nozzle.
    http://www.goulds.com/pdf/BJS+.pdf
Similar Threads: Second Opinion
Pumps and Tanks Well Forum & Blog Do I have really have a well water line leak? Need second opinion. Jun 19, 2014
Pumps and Tanks Well Forum & Blog Adding Second Pressure Tank Nov 21, 2015
Pumps and Tanks Well Forum & Blog My Scenario - Adding Second Holding Tank Apr 20, 2015
Pumps and Tanks Well Forum & Blog Second Tank installed on system - Not what I expected Oct 25, 2014
Pumps and Tanks Well Forum & Blog Pumptec only allowing pump to run for 5 Seconds Jun 4, 2012
