Sdr 35 fernco fitting
Gtomike06
Old river-Winfree, TX
Need to replace a couple foot section of 6 inch sdr 35. The only fernco fittings I can find are to loose on the pipe and fit over sch 40. Is there any other fittings made to join the sdr35 since I can't slide a fitting in? Thanks
wwhitney
Berkeley, CA
A few options (not exhaustive):
- It will probably work just by cranking down on the hose clamp, although I'm not a huge fan of that idea.
-What type of SDR35 pipe are you using? If solvent weld, gluing a hub from a piece of hub-end pipe onto the SDR35 will increase the OD, and it will probably end up very close to what the Fernco is intended for.
-Or they make thin solvent-weld bushings for this purpose, e.g. (random example):
-Never tried Fernco's HULK fittings, but the HULK5 says it will work for ODs from 5.30" to 6.7", so that should cover 6" SDR35 at about 6.3".
Cheers ,Wayne
Gtomike06
Cheers ,Wayne
Appreciate the options.
I may try and just crank down on it. Though about maybe putting a layer of electrical tape on it? But it says online the range for the standard fernco is 6.30 to 6.80. But man it sure looked loose on the sdr35 at the store.
I really like those hubs but doubt I'd be able to get some from a store tomorrow.
John Gayewski
Iowa
A regular bell end of sdr35 pipe is the size of regular sched 40 (or very very close). I think the coupling idea is good. Or you could simply cut some bell ends off and glue them on like a bushing.
