Sand to protect underground drain pipes? Also, two way cleanout question...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jeepnick, Nov 29, 2011.
  1. Jeepnick
    Jeepnick New Member
    Nov 24, 2011
    Phoenix, AZ
    I know my local code (UPC) requires that pressurized pipes be protected by sand (or clean fill?) before backfilling with dirt...
    But, does anyone know if there is a similar requirement for drain pipes? I'm getting ready to do underground drains for my bathroom addition and I'm wondering if I can just backfill over the pipes with the dirt I dug up (after inspection of course), or do I have to put down a layer of sand under and/or above the drain pipes?
    Also, I am putting in a two way clean out for the same bathroom addition. The pipe from the bathroom will be 3 inches, but the pipe it connects to in the yard is 4 inch clay. Can I use a 3" two way clean out, or do I need a separate clean out (matching the diameter of the pipe it serves) for each direction since one is 4 inches and the other 3?
    Thank you!
  2. hj
    Just make both cleanouts 4", and run 4" pipe to the clay line. The one towards the house will seldom, IF EVER, be used so it being oversized is not a factor. Use the same dirt to backfill. Before inspection, you have to pack the dirt around, and under, the pipe about half way up, it is called "shading the pipe". If you are in Scottsdale, or a few other cities, they REQUIRE that the water lines be enclosed with insulation for protection and heat retention, but then you can use the same soil for backfilling.
  4. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    I used sand in my basement because I needed to try to compact it under a fairly tight network of pipe.
    If you get enough water in there to saturate the sand, and then keep adding water, it will help.
  5. Jeepnick
    Jeepnick New Member
    Nov 24, 2011
    Phoenix, AZ
    Thank you for the detailed and helpful information! I really appreciate it.
  6. hj
    Just as a point of information, so far, I have NEVER "imported" sand or any other fill material for my water or waste lines.
  7. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Hey hj, Do you think it would make a difference in areas with highly expansive soils (clay)?
    (trying to learn, not disagreeing)
  8. dlarrivee
    Jun 28, 2009
    Canada
    I guess if you do all of your work in the exact same area, you might never come across rocks, clay, etc. etc.
Similar Threads: Sand protect
Plumbing Forum, Professional & DIY Advice Sand point pipe broke...how to remove it? Oct 27, 2015
Plumbing Forum, Professional & DIY Advice Cant prime my well, sandpoint, pipe inside casing Please HELP Dec 9, 2014
Plumbing Forum, Professional & DIY Advice Can I use a suspended sandpoint in pond for extraction in pond 100yds away? Pump,size?sink n shower, Dec 2, 2014
Plumbing Forum, Professional & DIY Advice HELP I got Sand in my pipes! Jul 28, 2014
Plumbing Forum, Professional & DIY Advice Advice on Whole House Sand and Sediment Filters Sep 10, 2013
