Rough-In Valve Install
Discussion in 'Shower & Bathtub Forum & Blog' started by Dogman, Apr 6, 2007.
  1. Dogman
    Dogman New Member
    Apr 6, 2007
    My first post here:
    Installing a new 4 port shower rough in a remodel walk-in and it's been about five years since I did one of these. The rough has threaded 1/2" female ports - what is the best way to plumb to the rough with copper? Since the female ports require a threaded male fitting which I assume calls for teflon tape, how do I sweat the fittings from there to the cut-offs without potentially melting the teflon? I thought that using four compression fittings (one for each port) might be the answer, but it seems like that is a lot of joints i:e potential leaks.
    Is there a simple solution I'm overlooking....??
    Relatively Handy Amatuer
  2. jimbo
    jimbo Plumber
    No compression.
    Now, did the teflon on your frying pan ever melt?
    It is OK to solder a fitting which is taped or doped and threaded. However, we often look for a method to not solder directly on it. It is often possible to sweat a street elbow and/or short pieces of pipe to the male adapter first, then screw it into the body. This makes the first joint you have to sweat some distance away from the taped joint.
  4. Dogman
    Dogman New Member
    Apr 6, 2007
    alternative
    excellent - never imagined that that thin white plumbers tape wouldn't melt!
    What's the opinion on using cpvc instead of copper?
Similar Threads: Rough-In Valve
Shower & Bathtub Forum & Blog Low water flow to a shower head can be caused by a low-flow rough-in valve/cartridge Apr 9, 2016
Shower & Bathtub Forum & Blog Grohe 35015000 Universal Pressure Balance Rough-In valve Feb 10, 2015
Shower & Bathtub Forum & Blog Stud interferes with new rough-in valve placement Dec 5, 2013
Shower & Bathtub Forum & Blog Delta Rough-In Valve for shower-only install Oct 21, 2013
Shower & Bathtub Forum & Blog A new rough-in valve thats deeper than the old Feb 26, 2013
