Rotten Egg Smell in Water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by housebldr2, Feb 27, 2006.
  1. housebldr2
    housebldr2 New Member
    Feb 27, 2006
    We removed the anode rod from our Hot Water Heater about a year ago because of the bacteria growth and smell we were getting from our well water. We are now told that this was a no-no and it will decrease the life of our HW Heater. Question I now have is they tell us there is an "aluminum" anode rod that is used in these cases. Isn't aluminum dangereous for health reason? (like the idea we were told do not use uncoated aluminum cooking pans).
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Shut off the cold water valve drain some water from the tank, open one of the nipples, and dump in a few pints of hydrogen peroxide. Close everything up and let some water run from all spigots and taps.
    The smell is caused by anaerobic bacteria. The peroxide adds oxygen to the water, killing them. Running the water gets the peroxide into your pipes and kills the bacteria there.
    But, if it stinks at one sink, but not all of them, dump the peroxide down the basin overflow, instead of into the water heater. Sometimes bacteria can build up in there, too.
    The peroxide will kill the bacteria for the time being, but more is coming in all the time and the next time you leave for a few days, the problem will return.
    One solution is to replace the magnesium or aluminum anode -- which reacts with the bacteria to make the stinky hydrogen sulfide gas -- with a zinc/aluminum alloy rod. In many cases, this will eliminate the odor. Turning up the water heater to 140 degrees will also kill this bacteria growth as well. I only recommend this for a short period of time. Anode rods are the "sacrificial" rod inside the tank so that the water attacks the rod, not the tank.
    Most tanks are glass-lined but they are done in a fashion that doesn't thoroughly cover all areas of the tank, especially gas water heaters with a center flue chase. I've seen how they do it; a spinning wand down the hot and cold inlet/outlet ports. Takes all but 4 seconds for them to do it and is not very effectively orchestrated. If they took more time and checked their work, it would probably make the tank last a great deal longer. Possibly the reason why the old OLD water heaters lasted as long as they did, they cared about the product they moved. Now it is all about job security and make it last past the warranty expiration.
  4. jadnashua
    Have you ever heard about sacrificial anodes used on boats? If you need one because of the construction, and you don't replace it when it wears out, you may not find much of your propeller left - it will just corrode away, and probably fall off what ever is left. If you want your hot water tank to last put an anode rod back in. You may have severly impacted its life, and depending on conditions, it could fail any time. The manufacturer won't warranty it, either.
Similar Threads: Rotten Smell
Plumbing Forum, Professional & DIY Advice Washer smells like rotten eggs Mar 29, 2014
Plumbing Forum, Professional & DIY Advice Rotten Egg smell when washer runs Apr 16, 2012
Plumbing Forum, Professional & DIY Advice Sulfer Rotten Egg smell after running water.... Sep 28, 2009
Plumbing Forum, Professional & DIY Advice Water smells like rotten eggs Jun 30, 2009
Plumbing Forum, Professional & DIY Advice Rotten Egg Smell In City Water Nov 14, 2008
