Roof leaks at chimney flashing
Discussion in 'Remodel Forum & Blog' started by Blumengarten, Sep 1, 2009.
  1. Blumengarten
    Blumengarten Member
    Nov 24, 2008
    new graduate
    Pennsylvania
    Hi Folks,
    I had a new asphalt roof put on my house two years ago. Almost immediately, I noticed that it was leaking around the chimney (it had leaked there before the new roof was put on) so I called the roofer and he put a couple tubes of up around there. I thought it was fixed and didn't notice any more damage until this summer when I decided to finally remove the plaster and fix the damage. With the plaster gone, I noticed that it's still leaking with every rainfall. I asked a neighbor who is a contractor and he went up and put another couple tubes of roofing asphalt up there, but it's still leaking! (The neighbor shook his head when I told him who put the roof on; I'd chosen the roofer because he'd put my mom's roof on 15 years ago and it's still leak-free.)
    How should this be fixed? More tubes of roofing asphalt? I live in Pittsburgh, we've had an extremely wet summer and we sometimes get very bad winters. The roof is rather steeply pitched so I'm not going up there myself.
  2. Cookie
    Cookie .
    Oct 7, 2005
    I would call back the roofer who put it on and tell him again, it is leaking. I would show him where it is leaking. I would have my contract out and sitting there and ask him, " now what are you going to do here?" Maybe, you could have someone with you who is experienced in this. I have an older neighbor I always use, I rent him by the hour for this stuff, lol.
    To me it sounds like the flashing isn't bent right around the chimney. My roofer makes his own flashing and mine is bone dry. Maybe, some tar?
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Sounds like it needs to be ripped out and redone. I'm not a big fan of just putting some caulk or putty and hope the problem goes away, that's just patching it blind.
  5. Cookie
    Cookie .
    Oct 7, 2005
    Yeah, I think you are right, he should take it down and redo the flashing. Good Matt, that's what the poster should do. Question, should the poster tell the roofer this? Suggest it? What? How should he handle it.
  6. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I didn't say he should redo it just that it needed to be redone.
    The poster should tell his roofer to fix the problem, not throw patch jobs at it.
  7. Cookie
    Cookie .
    Oct 7, 2005
    Yep, I agree, it needs redone. What does the question mark mean?
  8. Blumengarten
    Blumengarten Member
    Nov 24, 2008
    new graduate
    Pennsylvania
    Thanks, Guys. I thought it would need to be re-done but I wanted someone else's opinion.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    I just hope your contractor is honorable...
  10. Blumengarten
    Blumengarten Member
    Nov 24, 2008
    new graduate
    Pennsylvania
    Me too!!!!
  11. delta d
    delta d New Member
    Sep 11, 2009
    nashville
    flash and tar, sounds like some got greedy with one or the other.
  12. Roofer911
    Roofer911 New Member
    Jan 7, 2010
    Virginia
    Chimney Leak
    If the chimney counter flashing is good then the problem is most like caused by improper installation of the roof shingles around the chimney (nails exposed in flashing) or the source of the leak could be originating further up the roof and finding it's opening at the chimney. Putting tar on a roof is only a temporay solution, the source of the leak needs to be found and repaired to insure a permenent fix!
  13. modbit
    modbit New Member
    Jun 26, 2012
    Atlanta
    I would call the roofer, before trying anything else. Give him another chance to resolve the issue.
  14. Windows on Washington
    Windows on Washington Member
    Sep 25, 2012
    Exterior Construction
    Washington, DC
    Did the roofer repair the leak?
    2 years should be inside the warranty coverage on most roofing projects (especially if we are talking about a new roof). Anything that starts leaking in 2 years wasn't done correctly from the start. If you are relying on glue and caulk to make your water seal, you are doomed to failure.
Similar Threads: Roof leaks
Remodel Forum & Blog Roof Leaks Downslope of Penetrations Jun 11, 2007
Remodel Forum & Blog Tie hip roof into valley roof Dec 10, 2015
Remodel Forum & Blog Branch fell on roof Aug 23, 2015
Remodel Forum & Blog What Type of Roofing is the Best Suitable and Long Lasting? Jun 9, 2015
Remodel Forum & Blog Can I use expanding foam in roof eaves openings? Mar 12, 2015
