roman tub filler is only 2.5 gpm...
Discussion in 'Shower & Bathtub Forum & Blog' started by dianelouise, Jul 30, 2005.
  1. dianelouise
    dianelouise New Member
    Jul 30, 2005
    California
    I made a terrible mistake! :eek: I picked the Hansgrohe 1901 Interactiv faucets and then ordered the matching shower head, valves, and roman tub filler. We are finally getting around to install the fixtures and my dear hubby noticed the input lines for the roman tub are the same size as the sink faucets (3/8" copper). I quickly got on the internet and sure enough - the flow rate is only 2.5 gpm. I assumed that a roman tub filler would be sized to fill a big tub (at least 1/2" input supply lines). since the sink and shower faucets have been installed, is there anything I can do? I want everything to match, but I'm afraid that after 20 minutes to fill the tub, the water will be cold and I will be quite disappointed. Is there anything I can do (short of returning the faucets and purchasing a set that "sort of" matches - but has greater flow?)
    thanks in advance for the advise... diane
  2. dianelouise
    Jul 30, 2005
    California
    just to clarify - the individual hot and cold lines to the faucets are 1/2". Then in the mixing valve, where the water goes from the faucets to the spout, they drop to 3/8". Should I install the faucet and see if 2.5 gpm is "ok" or send it back before it's too late? thanks, diane
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    try it first
    I dont think that you are going to
    have a problem with this...
    they are not going to make a roman tub faucet
    fro a whirlpool tub that is going to only "piss " a stream into it.
    Call the factory and simply ask them
    first it that will ease your mind
    but you are most likely fretting over nothing
Similar Threads: roman filler
Shower & Bathtub Forum & Blog Roman tub filler trims for Kohler K-300-K rough-in? May 21, 2015
Shower & Bathtub Forum & Blog Maax Ella Sleek - No Roman Deck Filler Will Fit? Aug 21, 2013
Shower & Bathtub Forum & Blog roman tub filler in acrylic tub? Jul 24, 2012
Shower & Bathtub Forum & Blog Pressure balance on roman filler with hand shower? Feb 22, 2005
Shower & Bathtub Forum & Blog Roman tub fixture identification Saturday at 2:26 PM
