rolled vs. cut threads
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Yersmay, Jun 15, 2011.
  1. Yersmay
    Yersmay Writing, constructionDIY Member
    Sep 9, 2005
    writing, construction
    Los Angeles
    In another thread, HJ observed that a basket strainer had 'rolled' threads instead of machined threads. He said this was disadvantageous because a slip nut will not tighten properly to a rolled thread. I'm curious about this. First, by observation how can one see the difference between a rolled thread and a machined thread? Why is a rolled thread harder to make water tight? Do experienced plumbers generally avoid rolled threads in all threaded plumbing applications? Are rolled threads present in only male threads, or are they present in female threads as well? Thanks in advance.
  2. DanT
    DanT New Member
    Jun 3, 2011
    ohio
    the rolled threads are rounded whereas machined threads would be sharp at the edges
  4. SacCity
    SacCity In the Trades
    Mar 14, 2011
    Sacramento, CA
    Rolled threads are formed by running the blank through a die, and forming the threads by moving the metal, this changes the metal structure which does have an effect on strength and corrosion, but these issues are not relivant on a plumbing level. The other is that the roots and peaks of the threads will be rounded as it is uch more difficult to move the metal with a forming die that much.
    Cut threads are formed by cutting the metal away. These can be either straight or tapered threads, generally the roots an peaks of the threads will be sharp as it is easier to cut...
  5. hj
    Machined threads have a sharp apex, rolled threads are rounded and therefore since they lose the metal which would create the "point" they are slightly smaller, and a slipnut with a shallow thread, especially if it also has a rolled thread, may NOT have enough engagement to tighten.
  6. ballvalve
    Dec 28, 2009
    northfork, california
    Rolled threads are how 99% of all bolts are made. They have an advantage of some work hardening, and can have a rather sharp apex.
    A cut thread, in the case of a acme or whitworth thread can have a flat and large apex.
    Strainers that cost less that 25$ are why the nuts do not hold. Rolled or not, the material is too thin and the nuts are die cast junk.
  7. hj
    Bolts do NOT make "rolled threads" by distorting the "wall" of the metal to create the thread. It is IMPOSSIBLE to roll 'thin sheet metal" into a thread without creating weak spots if the "bend" is too severe. THAT is why they are "rounded" and also why they seldom tighten into a conventional slip nut. I use cast brass strainers; they do NOT cost $25.00, the metal IS thick enough to machine threads, and they DO tighten properly.
  8. ballvalve
    Dec 28, 2009
    The cheap ones seem to be rolled on a mandrel, that works. The cast ones of course are best.
Similar Threads: rolled threads
Plumbing Forum, Professional & DIY Advice Does Soft Rolled Copper get harder over time Aug 9, 2012
Plumbing Forum, Professional & DIY Advice Computer-controlled digging for water main replacement? Aug 2, 2007
Plumbing Forum, Professional & DIY Advice Sealing pipe threads with large gap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Rate these NPT threads (black pipe) Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Leaking threads ... Sep 24, 2016
