Rocking Toilet
Discussion in 'Toilet Forum discussions' started by jockwalker1@mac.com, Aug 22, 2007.
  1. jockwalker1@mac.com
    jockwalker1@mac.com New Member
    Sep 25, 2006
    I am sure this question has been asked a million times. After installing our new toilet, there is slight movement from side to side. I put a small shim on one side to keep it from rocking. Is there a better way to correct the problem? Thanks!
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    If the toilet is seated properly on the wax, and the bolts are tightened down, and it still rocks a bit, using a shim is the correct course of action.
    The only other thing I can think of is to level your floor better, which is a much bigger project.
    I forgot to mention that caulking the base will also help stabilize the toilet.
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Iuse sanded grout where base meets the floor.It will not stick to the floor
    or toilet.i have this to many times to count.Keep the shim.it also looks niceif done properly.
  5. jadnashua
    If the toilet rocks after initial setting of the toilet, you should remove it and install a new wax ring. Since the wax doesn't rebound from the rocking, you've likely got a break in the wax seal. You may not notice until there is a backup or if the sewer gas smell is strong, but it is there. Mark where you need the shim, maybe tape it down so it doesn't move, then push the toilet down onto the new wax ring. Since it should no longer rock, the seal will stay intact.
    [​IMG]
  6. jockwalker1@mac.com
    Sep 25, 2006
    Thanks everyone! All good ideas.
Similar Threads: Rocking Toilet
Toilet Forum discussions Rocking Toilet Feb 7, 2015
Toilet Forum discussions Rocking Toilet Sep 24, 2013
Toilet Forum discussions New toilet and the tank is still rocking Jun 24, 2012
Toilet Forum discussions New toilets rocking! 3" plastic pipe? Nov 29, 2008
Toilet Forum discussions Rocking toilet Apr 5, 2008
